Well, i dunno - you're all like 'it did achieve something' without explaining what. Where-as SydneyKid has explained fairly comprehensively in this thread (and others) that the design of the R33/R34 chassis means that a rear strut brace won't improve handling that much - just improve chassis rigidity somewhat - and would be one of the last things you'd do.
So please - and I'm not trying to be nasty here - what improvements/achivements did it give your car in your opinion - and what other suspension modifications has it already got? One of the whole points of this thread (it seemed to me) would be that the OP was trying to determine whether a rear strut brace would be worth it. So your input about what improvements you've noticed (especially in relation to whatever suspension mods you already have) would be useful for them.
Without getting technical (because I'm not an engineer / mechanic), the bar just stabilized the rear through cornering, either at mid-range / high-range speeds. When the back gets loose, it's even more noticeable.
Other suspension changes:
TEIN coilovers
Standard Front Strut Brace
Cusco Rear Strut Brace
Cusco Front Tension Brace
JIC Adjustable Castor Rods
BEE*R Pineapples
HICAS Elimination Bar
TEIN coilovers
BEE*R Pineapples
It's impossible for a rear strut brace on R33/34's to "stabilized the rear through cornering". In R32/33/34's the control arms are attached to the rear subframe not the body, so sticking a strut brace between 2 parts of the body doesn't do a single thing for maintaining the rigidity of the mounting for the upper and lower control arms. So the suspension angles, camber, toe and bump steer benefit nothing from the addition. All it achieves is the linking of the top mounts of the spring and shock units, which in a double wishbone car contributes nothing to maintaining the suspension geometry.
This is especially so in an R33/34's where the parcel shelf support structure already does a good job of linking the strut tops. In R32's, where the strut tops are mounted lower, at the inner guards, and are therefore not joined by the parcel shelf, there is a slightly better argument for a rear strut brace, but even then the effect is miniscule. Unnoticeable by even the most sensitive of drivers.
I should mention that this is not the case with the front strut brace on R32/33/34's, because the front upper control arms are mounted to the body ie; the inner guards. So linking the inner guards adds noticeably to maintaining the rigidity of the mounting for the upper control arms.
Technically what your are feeling with the rear strut brace is placebo effect, you spent the money, you put something on the car that looks good, so it must work and therefore you truly believe that you can feel it. If you don't believe the facts then that's your choice. But if you want to prove to yourself that it's true then a blind test is the only method, have someone remove and replace the rear strut brace without telling you, then you try and pick it. I've done it on an R32 and even a current V8SuperCar driver couldn't get it right more than half the time, mere mortals like you and me have no chance. ;)
Cheers
Gary
  • 1 month later...
dont waste ur time with rear strut brace. (especially the jjr ones they r very shit it actually put my boot out of line lol)
if u want better handling get the following
coilovers
camber
caster
pineappleas
sways (these r the most important i reckon)
awesome tyres
awesome brakes and pads
and if u wanna go the extra step get a cage as well
Damn you SydneyKid! In another thread called "what fits in your boot" or some crap I admitted that I made a custom fibreglass esky to utilise the minimal space of my r33 boot, but then I bought a rear strut brace and it "clashed"
Now I read your bloody logical argument that this was a pointless addition and I'm pissed off.
Well I say, there are some things we don't wanna know. Important things!
Ignorance was bliss. Can't you just talk crap and call everybody thick based on heresay and Wikipedia-sourced info like so many others? Or admit you're trying to sell swaybars as the primary motive behind this?
I need a drink.......
  • 3 years later...
see
Hey GUN_METAL_GTR32,
Did you end up getting this fitted? I have brought one from JJR and it is advertised as "Direct Fit" but when I bolt it up my boot lid wont close I have it the exact orientation as the pic you uploaded... Am I missing something here?
Cheers man
KT
My R34 has the factory fitted rear strut brace and a factory fitted brace between the spare wheel well and the back of the car to stiffen it up , so I don't think it is just for marketing purposes
Now if someone could make these out of titanium, that'd save some weight!
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
