  • Replies 181
Had a bit of a heart flutter this morning when I realised it was Thursday already!
Car hasn't been run since Phillip island, brakes aren't bled, haven't finished bolting in cage let along padding it, have to put interior back in, have to fix water leak coming from somewhere around inlet manifold!
I better go through the bottle-o on the way home, it's gonna be a late one in the garage! The misses offered to give me a hand, she'll have to be beer wench?
I belive there will be a few photographers up there on the day, and also i belive Martin and crew will have their videos recording...
The more the merrier though... love to see as much footage and pics as possible...
Have most GTR owners upgraded their handbrake shoes or are using hydraulic handbrake?
With RE-01R tyres and standard handbrake inner shoes my BNR34 simply wont brake free in the rear no matter how viscious I am in trying to get the tail around. (Be it a sharp opposing turn first and then catching the change in inertia as the weight transitions whilst applying handbrake - she just wont budge)
Looks like I might be gripping it around those tight turns unless there is a trick I'm missing!??
Looking forward to my first DECA day in the [R] so see you all there! :sick:
Cheers,
Ben
Great,
I'm not 110% committed yet but I have a feeling my scheduled commitment for the weekend will be postponed.
Whomever else is planning on bringing video equipment, shoot me a PM if you'd like to co-ordinate a proper production of this event.
PEACE.
Yep - Project Mu or URAS drum hand brake shoes.
Have tried hydraulic. Don't do it, it's gay. ABS and 4WD computer doesn't like it much.
Hanbrake shoes work great if your cable is tight and the little adjuster that sits in between the handbrake shoes is set properly on both sides.
shep forecast
Forecast for Saturday
Sunny day. Winds east to northeasterly averaging 20 to 30 km/h.
Precis:
Sunny day.
Min
9
Max
22
noice
going to be a fun day
Thanks for the clarity, appreciate it.
I'll have to source some for next round as I'm $hit out of luck locating & having these installed tomorrow - doh!
Cheers
Ben
just an update [beza] will no longer be participating as he has some stuff to do back home instead, so i don't know how the reserves will work this late but yeh just letting you guys know.
cheers
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
