  • Replies 181
Had a bit of a heart flutter this morning when I realised it was Thursday already!
Car hasn't been run since Phillip island, brakes aren't bled, haven't finished bolting in cage let along padding it, have to put interior back in, have to fix water leak coming from somewhere around inlet manifold!
I better go through the bottle-o on the way home, it's gonna be a late one in the garage! The misses offered to give me a hand, she'll have to be beer wench?
I belive there will be a few photographers up there on the day, and also i belive Martin and crew will have their videos recording...
The more the merrier though... love to see as much footage and pics as possible...
Have most GTR owners upgraded their handbrake shoes or are using hydraulic handbrake?
With RE-01R tyres and standard handbrake inner shoes my BNR34 simply wont brake free in the rear no matter how viscious I am in trying to get the tail around. (Be it a sharp opposing turn first and then catching the change in inertia as the weight transitions whilst applying handbrake - she just wont budge)
Looks like I might be gripping it around those tight turns unless there is a trick I'm missing!??
Looking forward to my first DECA day in the [R] so see you all there! :sick:
Cheers,
Ben
Great,
I'm not 110% committed yet but I have a feeling my scheduled commitment for the weekend will be postponed.
Whomever else is planning on bringing video equipment, shoot me a PM if you'd like to co-ordinate a proper production of this event.
PEACE.
Yep - Project Mu or URAS drum hand brake shoes.
Have tried hydraulic. Don't do it, it's gay. ABS and 4WD computer doesn't like it much.
Hanbrake shoes work great if your cable is tight and the little adjuster that sits in between the handbrake shoes is set properly on both sides.
shep forecast
Forecast for Saturday
Sunny day. Winds east to northeasterly averaging 20 to 30 km/h.
Precis:
Sunny day.
Min
9
Max
22
noice
going to be a fun day
Thanks for the clarity, appreciate it.
I'll have to source some for next round as I'm $hit out of luck locating & having these installed tomorrow - doh!
Cheers
Ben
just an update [beza] will no longer be participating as he has some stuff to do back home instead, so i don't know how the reserves will work this late but yeh just letting you guys know.
cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
