Hey peeps.
I have done a search on the Kumho KU36's everywhere and cannot find any reviews on the tyre related to the actual tyre performance on the track.
If any one is running these tyres currently on their track cars "grip" and have been out on the track, I would love to hear your oppion on how they performed against some of the more expensive semi slicks ie yokohama advans, silverstone falkans etc.
Basically trying to decide whether or not to buy these or just to save up the extra and buy something that has been tested and proven with ratings.?
Cheers in advance,
BB
https://www.sau.com.au/forums/topic/266168-kumho-ku36/
  • Replies 50
I've never run the ku36, but the kumho semi slick is the v70A which is a pretty good tyre. Not sure that it is as good as dunlop dz03 or bridgestone re55 but it is much better than the yoko 32/48 tyres.
The ku36 looks more like a street/track tyre like federal 595rs or falken rt615.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4543479
Why are people trying to compare the Ku36 to RE55's/A050's/R888's ???
Nothing I've seen suggests the Ku36 is a semi-slick. From memory the treadwear rating on the Ku36 is about 180, compared to the usual semi-slick of 80-120.
They seem to be a decent road tyre, but thats about it. I think the Kumho marketing team is getting a little ahead of themselves in terms of promotion...
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4546773
There is some info in this thread
http://www.skylinesaustralia.com/forums/Ty...=ku36&st=20
Faster than a road tyre by nearly 2 seconds a lap. Not a real track tyre but if own one set of rims its a smart choice given the price.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4554305
  • 3 weeks later...
The newer federal RSR model now has a treadwear rating of 140. It also has a much stiffer sidewall than the earlier RS model. I am going to give a set of these a workout as soon as the car is back up and ready for time attack.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4590272
Don't compare treadware numbers BETWEEN manufacturers. They can only be used as a very rough comparison - best kept to compare between a single manufacturers tyres.
I'll say I've VERY happy with my Sumitomo ZIII (Z3). Prob a touch more street than the KU36 but a very stiff sidewall if getting the usual extra load ones.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4594697
does anyone have any idea what sort of kms can be expected out of a set of these tires? im very interested in them given the price and like to do a bit of spirited driving and plan on attending the track on the odd occasion however my car is a daily driver so i dont really want to be replacing the tires again after 10,000 kms...
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4598672
  • 4 weeks later...
which tyre is softer the kuhmo ku36 or the toyo r888
these tyres are not really comparable. The Toyo R88 is a semi slick and is far softer compound than the road tyre KU36.
Ive tried a set of 275s ku36's and wasnt overly impressed by them. Grip around corners was nothing special and down at the drags i had a slower 60ft compare to my bridgestones. But for the price they aint to bad.
I don't know what sort of Bridgestones you had, but the KU36 were worth 2.5sec per lap at QR and 2.2sec at Lakeside over Federal 595SS onmy Supra.
Any updates as to the performance of the KU36 at track days?
good - for what they are. Do not buy them expecting semi slick levels of performance. They're an "Ultra High Performance" road tyre, really designed for people who do the occassional track day and can't justify the expense of semis and another set of rims.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4690036
  • 3 months later...
On Wakefield 1.5 sec slower than semi's, they only start to work well at 38-40psi (hot). I wouldn't suggest using them as a drag tyre without a resonable burnout. Better than most road tyres, great for the money.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4863038
  • 3 months later...
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
