Hey peeps.
I have done a search on the Kumho KU36's everywhere and cannot find any reviews on the tyre related to the actual tyre performance on the track.
If any one is running these tyres currently on their track cars "grip" and have been out on the track, I would love to hear your oppion on how they performed against some of the more expensive semi slicks ie yokohama advans, silverstone falkans etc.
Basically trying to decide whether or not to buy these or just to save up the extra and buy something that has been tested and proven with ratings.?
Cheers in advance,
BB
https://www.sau.com.au/forums/topic/266168-kumho-ku36/
  • Replies 50
I've never run the ku36, but the kumho semi slick is the v70A which is a pretty good tyre. Not sure that it is as good as dunlop dz03 or bridgestone re55 but it is much better than the yoko 32/48 tyres.
The ku36 looks more like a street/track tyre like federal 595rs or falken rt615.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4543479
Why are people trying to compare the Ku36 to RE55's/A050's/R888's ???
Nothing I've seen suggests the Ku36 is a semi-slick. From memory the treadwear rating on the Ku36 is about 180, compared to the usual semi-slick of 80-120.
They seem to be a decent road tyre, but thats about it. I think the Kumho marketing team is getting a little ahead of themselves in terms of promotion...
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4546773
There is some info in this thread
http://www.skylinesaustralia.com/forums/Ty...=ku36&st=20
Faster than a road tyre by nearly 2 seconds a lap. Not a real track tyre but if own one set of rims its a smart choice given the price.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4554305
  • 3 weeks later...
The newer federal RSR model now has a treadwear rating of 140. It also has a much stiffer sidewall than the earlier RS model. I am going to give a set of these a workout as soon as the car is back up and ready for time attack.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4590272
Don't compare treadware numbers BETWEEN manufacturers. They can only be used as a very rough comparison - best kept to compare between a single manufacturers tyres.
I'll say I've VERY happy with my Sumitomo ZIII (Z3). Prob a touch more street than the KU36 but a very stiff sidewall if getting the usual extra load ones.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4594697
does anyone have any idea what sort of kms can be expected out of a set of these tires? im very interested in them given the price and like to do a bit of spirited driving and plan on attending the track on the odd occasion however my car is a daily driver so i dont really want to be replacing the tires again after 10,000 kms...
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4598672
  • 4 weeks later...
which tyre is softer the kuhmo ku36 or the toyo r888
these tyres are not really comparable. The Toyo R88 is a semi slick and is far softer compound than the road tyre KU36.
Ive tried a set of 275s ku36's and wasnt overly impressed by them. Grip around corners was nothing special and down at the drags i had a slower 60ft compare to my bridgestones. But for the price they aint to bad.
I don't know what sort of Bridgestones you had, but the KU36 were worth 2.5sec per lap at QR and 2.2sec at Lakeside over Federal 595SS onmy Supra.
Any updates as to the performance of the KU36 at track days?
good - for what they are. Do not buy them expecting semi slick levels of performance. They're an "Ultra High Performance" road tyre, really designed for people who do the occassional track day and can't justify the expense of semis and another set of rims.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4690036
  • 3 months later...
On Wakefield 1.5 sec slower than semi's, they only start to work well at 38-40psi (hot). I wouldn't suggest using them as a drag tyre without a resonable burnout. Better than most road tyres, great for the money.
https://www.sau.com.au/forums/topic/266168-kumho-ku36/#findComment-4863038
  • 3 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
