Hey all.
Looking at new sump for my 25/30. Its going into an R31. Will i have any clearance issues with swaybar/crossmember and the like if i get one of these enlargened sumps.
Are the RB30 sumps the same for both the VL and R31 RB30's?
Thanks for any assistance,
Chris
https://www.sau.com.au/forums/topic/266179-high-energy-sump/
High Energy make their RB30 sumps to fit into skylines. The old design would have clashed with the swaybar in a skyline (have one at the workshop, was off my RB30 when it was in my mates commodore), I measured up my mates one and rang High Energy to begin explaining what I needed (a 50mm 45deg chamfer off the leading edge of the extension) and he was like "oh, we already do that now for all RB25 and RB30 sumps".
I will be getting a pro-circuit High Energy sump, was meant to already be got but decided to get some Spool rods and needed to get a 6boost manifold :)
Edit: can't see anything about baffles & gates in that JPC sump..
Edited by bubba
I'll have a look closer at all of the above. I did notice that the Lewis Engine's one doesnt make any references to additional baffling and the like.
Thanks for that gents.
Edited by sxc33
I've decided to bite the bullet and get the ASR sump. Spent too much money already, whats a few more dollars lol.
For those interested, apparenlty the sump will still fit a 31 all right - incase anyone else is doing the same sorta thing.
Cheers for the tips lads
Chris
Just Jap sell the ASR sumps.
I emailed Lewis Engines about their sump, they didnt show any photos, but they claim their sump sump is a proven design which has been fitted to hundreds of track, and drag cars. They also offer another sump for $699 designed for even heavier cornering, acceleration and braking.
Got any pics of the "hardcore" one?
I fitted an ASR sump to one of our commodore cup engines yesterday and they are a work of art. Just make sure you pull out the screen and wash it out properly as there will still be some metal dust and shavings from the fabrication. All the parts are laser cut and well finished and the welding is perfect. This sump was $1300 but you can see the dollars in it. I can't imagine something less intricate costing anywhere near that. though.
I have a mate currently making an RB30 one for me, I'll snap some photos when it's done. We're going to have the pans and baffles laser cut and cnc bent once we have the prototype done.
Sweet as. I like pictures lol
No it doesn't, at least in my R32 GTSt the standard RB30 sump doesn't hit the swaybar.
It is the extended sumps that might have problems but High Energy now take into account the swaybar in skylines for all their RB25 & RB30 sumps.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
