nick you kinda werent invited, rosie is welcome tho
haha only kidding mate :)
i rekon make the meet time 7.30ish as some of us dont get home till late. plus andy drives like a volvo driver so it will take him longer to get there :P
:D:wacko:
:D
:P
  • Replies 356
wat do u guys recon..?
i have never seen another M35 on the road with me..
any1 keen for a meet up?
Yeah I'm all for a meet up, but the thursday truck stop one doesn't work for me. . . Oh and I am a M35 owner over 30. . . . LOL
Wouldn't mind a metro catch up, that way us city folk can make it. . . a good old BBQ - aka bring a plate event would work. . . just a suitable venue to accommodate some cars, places that come to mind are
Bobbin Head. . yes more north but ample BBQ & parking
Jubilee Park - Glebe
Homebush near the lake - not sure if they have BBQ's
Just a thought. . . . . . .
Edited by Paramour
Some good idea's coming out of this :P
I'll keep my eye on the forum, so far it's looking like a weekday evening might be the go?
Let's work out where the bulk of the people are from and find a central area based on that data.
I would be coming from Blacktown.
Northern Beaches. . .
[[d a n n y]]
zei20l
andy65b
kng35m (depending on location)
daleo
jetwreck (if it's in 3 or more weeks time)
paramour
hydra
crisis
bis-e bee
bezerkr32 (if weekend cruise)
11 expressions of interest so far, not bad!
And maybe we should make this something we do every 3 months or something?
Anyways, make some more suggestions :P hopefully we will find something that will keep everyone happy.
[[d a n n y]]
zei20l
andy65b
daleo
paramour
hydra
crisis
bis-e bee
Anyways, make some more suggestions :wub: hopefully we will find something that will keep everyone happy.
You left Alex and I out, Stephen - how bloody rude!!! :P j/k
Danny, does Rhodes Shopping Centre have a little cafe of some sort right near the carpark? It's been quite a while since I've been there, so I can't remember. If they do, then that (or maybe Auburn McD's and KK's) would work out best - fairly central to all and easy to find (especially Auburn).
Lol... Does sound kinds ghey..
... says the lonely VIC M35 owner on these boards. (You don't count as of today Nic!)
Only two sleeps to go.. :P
Then I will be a NSW M35 owner for about 12 hours...
Then I will the other VIC M35 owner on the forum...
Should mention, that I did see a M35, not blue in colour, past Fountain Gate the other week... so there are more out there..
I can organize a car-park/location down the end of Leeds street in Rhodes after hours if we need a venue.
just an FYI though...if FW's start doing heli's or stupid shit it will stuff it for us all.
unless some 1 has the mental age of 17 :)
Hahaha, Jetwreck and I were joking about that earlier... :D Even though we're both at least double that age, chronologically! :)
Seriously though, I doubt anyone would be stupid enough to do something that will spoil it for all of us.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
