Here's a simple test.
First, obtain a tennis ball in the opposite hand that you throw with.
Subsequently, go outside your house, find a nice spacious brick wall, and through it at the wall.
Then, inspect the wall to see if there is any damage...
Same principle applies to air hitting the turbo fins.... :):ph34r:
Yeah we gather the fact that pressurised air won't damage metal compressor fins.
I am much more worried about the shock loading on the bearing cartridge as the wall of pressurised air hits the rapidly spinning compressor :D:bunny::bunny:
i.e. your simple tests mean shit (thats why I raised you 1 bunny)
Edited by 09ONE_32
  • Replies 53
I would just like to throw out there that there are a lot of "problems" in the automotive world that MUST be fixed that like to pop up right after somebody starts making a product to "fix" said problem. It seems like people make a product and invent the "problem" to sell their wears.
Like how the sales of bottled water took off after the statistic was released stating that we need to drink at least 2l a day?
I am much more worried about the shock loading on the bearing cartridge as the wall of pressurised air hits the rapidly spinning compressor :bunny::bunny::bunny:
To see how compressed air will affect the bearing cartridge, perform the following:
Place a Ping-Pong Ball and hold it with your big toe in the foot you use the least.
Try and throw it at a brick wall.
Sample principle applies to compressed air having a load on the bearing cartridge.
Your bunnies don't mean shit, that's why I raised you a bananna (which is worth 3.34 times that of the bunny) :banana:
Age old debate that people seem to miss the main physics of...
Blades don't stop spinning... The blades are setup uni directional, that is, spin them one way, they move air, spin them the other, they do 2/5ths of f**k all.
Secondly, the "chopping" noise is the fact that the pressure applied by turbo is less then that in the pipe, so high pressure flows out the cooler pipes towards air filter.
Suddenly, pressure applied by turbo is greater, so some air gets sucked back in. Making a low pressure... This process continues... Making sound waves...
No damage to turbo.
Also, for those stating it causes more lag between gear shifts, it only causes more lag if you keep the pressure source for the wastegate on the IC piping. Run it to the manifold, no issues what so ever.
interesting. please explain.
150,000km's on the stock turbo running 1 bar with no bov sold with no shaft play then went on to a larger turbo for a good 70,000km's no bov @ 1bar, sold with no issues and now a bigger turbo again for 20,000km's no bov with no issues running upwards of 24psi.
I found it reduced lag on gear changes especially noticeable when putting in around traffic slightly on boost with all - straight off the actuator (pressure source comp housing), with an MBC and now with an EBC.
And... Nothing wrong with the ol' VLT's.
I personally hate the sound of aftermarket atmo bov's. For myself its either a a tight aftermarket recirc bov that doesn't vent until 20psi odd or no bov at all.
VLT's have been getting around with no bovs running close to 2bar since some of you were in nappies.
IMO emissions and drive ability at part throttle is all bovs are for. :laugh:
Edited by TheRogue
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
