4.3 Transmission: The design of the transmission is free, save for the following:
<snip>
• Four-wheel drive is permitted on cars originally produced in that configuration, however they must remain in “floorpan” construction and retain the original engine block and cylinder head/s for that particular vehicle model.
<snip>
4.4 Engines:
(iii) To establish total engine capacity.
• A multiplying factor of 1.7 applies to forced induction engines.
• A multiplying factor of 1.75 applies to rotary engines.
(iv) The maximum engine capacities are:
  • Naturally-aspirated reciprocating 6000cc
  • Naturally-aspirated rotary engine 3428cc
  • Forced-induction reciprocating 3529cc
  • Forced-induction rotary engine 2016cc
So...
RB26 has a "capacity" of 2568cc x 1.7 = 4365cc?
RB30 has a "capacity" of 2998cc x 1.7 = 5096cc???
Do the two clauses mean that we are unable to run RB30s in 3D logbooked cars?!? :P
https://www.sau.com.au/forums/topic/266486-3d-sports-sedans/
  • Replies 48
there is no requirement in 3D Sport Sedans to retain original block.
RB30 with forced induction can be used:
the limit on the total engine capacity for Sport Sedans is 6000cc. There is a 1.7 multipling factor applied to forced induction engines. So the maximum capacity engine that can be used with forced induction is 6000cc/1.7=3529cc.
All CAMS rules are a PITA to interpret until you get the hang of them.
My mistake - I didn't read the entire set of rules. I just based it on the fact that Sport Sedans has always been "engines are free", and I had a skim over the engines section and it was still the same... I see they snuck that engine rule for 'floorpan vehicles' into the Transmission section of their rules. way to make life difficult CAMS!
Thanks for the clarification guys :)
Doesn't the OS Giken kit retain the use of an N1 block? ;) That would satisfy the rules...
yep, it's a high deck/spacer kit with liners and stroker crank. and it uses the original block. so technically you should be able to use it. when they list the size limits for turbo engines that is before the 1.7 multiplier is applied. so you can go up to 3.5l.
also of course 2.8 strokers are no problem and there are plenty of those around. and I think the race pace 2.9 uses an RB26 block.
LOL, yep, so would the monster engine that Racepace screw together.
LOL, i wonder if the wording is loose enough with retaining origina block that you can just put the bare block on the middle of the car and run a 6L Chev with a diff in the sump just in front of it :)
way to post while I was posting. now I look dopey!
and yes run the RB26 block in the boot. just like group A rules where if a car was factory fitted with an AFM you must retain one and have it plumbed into the intake tract. says nothing about it being the primary load sensor, so you screw it to the inner guard, hook up a tiny 5mm vacuum line to it and use a map sensor to run the engine like you wanted too. all legal. ;)
but seriously, I think in this case you'll be restricted to actually using a 26 block for the engine. but that's no problem. you can get plenty of power and plenty of response out of a 26 block based motor. just get a nice close ratio box, and a nice rev limit and away you go.
yeah the rules will not allow an rb30 in a 4wd. there are a lot of freedoms when they say "standard block" covered in 4.4 part 4 but I don't think they are relevent to rb26 unless you want to make your own block.
However, you can still:
sleeve the block
space the head up
shoehorn an rb30 crank in the 26 block
go way oversize on pistons.
so there are plenty of ways to get to 3 or maybe even 3.1 litre.
but in any case why bother when you can get sufficient power out of rb26. 450awkw should be enough for most cars and more is possible if you want to spend enough.
re the rules - this is just the usual CAMS being stuck 20 years behind the times and protecting the "old" way of building race cars. Production cars are full of 4wds but they are banned in every other category because they go too fast. good irony for racing.
so 4wd are stuck with much higher minimum weights and original block. together this means gtr is about the only car with a genuine outright chance and even then it would be a long shot. CAMS are doing everything they can to keep 6l chev dinosaurs instead of 3.4l rbs.
not sure that they got the balance right even so, the BSM GTR was a genuine 4th in the NSW champs. still about 2 sec off the front runners but a very good start for such an under-developed car
Im with Duncan you dont need a big stroker or bucket loads of grunt.
You need massive corner speed to be at the pointy end, after watching far to many in car laps and recorded races lattely the quickest cars are carrying far more corner speed than the others but the outright acceleration was nothing that a 400Kw GTR could not acheive.
Unfortunatly to get a GTR cornering like a space framed calibra is a massive massive ask. Even if you have bulk grunt and limitless torque your not going to catch the chev in a straight line because he exited with 30Km/h more speed than you did.
in all seriousness....you would only ever get pinged for running an rb30 if you took it full circuit racing. for 99% of cars a sports sedan log book with an rb30 will sneak through fine - there is nothing a scruitineer would pick up on unless they are looking for it (they focus on safety not eligibility). This is exactly the same as improved prod GTRs...there are a few out there but you can be confident they don't run the required 32mm restrictors. There are 3 production GTRs I know of too and none of them run standard boost except when doing NSW champs racing.
our sports sedan is currently 2.6l but I was expecting to chuck rb30 in there next. if cams aren't happy they can shove it an I will do track days and AASA. the only thing I'll miss out on is CAMS NSW race series in 3D but I don't have 200k a year to be competitive there anyway
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
