Well can confirm if you clean throttle plates and "bore" of throttle body with carby cleaner you will afterwards be able to see light past the edges of the throttle butterfly 100%
for the record this was the same with crc carby cleaner and motorquip carby cleaner
God I hope that tomei stuff I ordered this morning works
But you should be able to see light, the throttle plate should not contact the bore
Yeah had figured that 2 :rofl:
yet car ran and idled fine when chocked with carbon so you definitly couldnt
see any light???????????
The "bore " on mine is definitly looking silver now not black as in the posted pics
Just not wanting to risk problems on starting a fresh motor
:D:)
guess I may be panicking about nothing
checked the manual again to be sure and there is nothing in there about setting these
plenty on setting the other linkages with feeler gauges etc nothing on setting
the butterflys up though :D
Edited by noone
you can do a cleanup without any problems as long as you're sensible about it. most of the time the problems that people experrience are because the re-assembly may not have been done correctly, or there was a small thing that was overlooked.
http://www.tomei-p.co.jp/_2003web-catalogu...hers_gauge.html
link to the Tomei site showing application of Tomei throttle coat to the Butterflys
not to the bore of the throttle body at all
So went back down to the shed to check mine out
to find this on the exact same spot as in the pic on the Tomei site
Add to this the fact that I could barely blow any air down the supplementary air pipe
till I cleaned the throttle body bore where the butterfly contacts (well almost contacts) the bore
you can see said hole below and the pipe I am referring to is clearly visible in the Tomei pics
despite the pic it looks like this side didnt have the aprox. 6 -10 mm of coating the other side did
again exactly as per the tomei pics
If I hadnt of cleaned the throttle body bores I reckon this hole would of been so clogged as to have been almost useless
  • 10 years later...
Huge thread Necro, will be cleaning my throttles and this thread has been a help. Quick question, how do you remove the butterfly shaft? Do I need a press to remove it and the bearings? Unfortunately whoever owned before me put copious amounts of liquid gasket under the end plates to try and seal them.  I have scraped it all back but trying to remove the butterfly shaft has been useless, it feels locked in. Don't want to brake it but I think if I can get it lined up in a press it should just press straight out correct? Thanks
Yeah mate, gotta press the shaft out, I did them on my 32 last year. I put a Reimax throttle refresh kit through it and new Nismo throttle springs, about a $300 exercise.
The Reimax kit is the only way to get those stupid plastic spring locator bits (they are always broken in most 26s I've seen) and shaft seals new. Nissan don't sell the bits as the throttles are not supposed to be disassembled - they are sold new as a complete unit.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
