Used parts:
6boost Steampipe manifold, high mount, T3 flange, external gate (only used for 2 months) $1000
Custom RB25 polished inlet plenum $650
Q45 throttle body $280
Z32 Air flow meter w/plug $250
ER34 RB25-NEO PowerFC + hand controller $1300
Denso 670cc injectors + rb25-neo fuel rail $950
Tomei type a poncams to suit RB25 neo $700
Splitfire Coilpacks DIS-008 $450
Carbon Fibre coilpack cover for RB25 neo $200
email [email protected]
https://www.sau.com.au/forums/topic/267738-rb-engine-parts-for-sale/
  • Replies 44
then the 260 degree in/ex 9.15mm lift are type b.
if thats definately consider them sold.
but only if 100% definate as you first stated as type a.
ive sent you an email...
consider the 260 cams sold so dibs for me.
ER34 RB25-NEO PowerFC + hand controller - SOLD pending payment confirmation
Tomei type a poncams to suit RB25 neo $700 - on hold pending payment
Splitfire Coilpacks DIS-008 $450 - on hold pending payment
hay buddy
do u still have the carbon fibre coil pack cover. if so conside it sold
pm me please
and could i have a pic of the plenum please buddy
cheers
julz
Edited by GUN_METAL_GTR32
plenum is fitted to NEO head. idle is fine, was tuned to idle at 850rpm, over 300kw. Has individual throttle "velocity stacks" inside and throttle response is great with a GT3540.
does it come complete to install, if not what is required?
thanks for your speedy response.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
