  • Replies 94
Posted Images
as for the other mods, I gotta admit, whatsisname is hands down much more "hunier" than sled
so we have
heslo - your skinny kinda gay guy
whatsisname - buffed manly gymer, guys only gym, I bars the hot tub !!!
andrew - for those cold winter mornings, snuggles !!
and then Sled coming up the rear
:blink:
https://www.sau.com.au/forums/topic/267993-mod-love/page/2/#findComment-4569147
I just felt some vommit in my mouth....and it had nothing to do with the lovely meal tonight! :)
Flamin Faggs!
you know u started this lol
if you and PK hadnt gotten brownies this never would have happened haha
so really you only have yourself and pk to blame haha
and tangles as for SLED coming up the rear........im not going there
https://www.sau.com.au/forums/topic/267993-mod-love/page/2/#findComment-4569245
