This engine was originally built with the intention of replacing the RB20 in my 4 door 32. It soon became apparent that, that wasn't going to happen and a better home for it would be in a GTR, but since i don't own a GTR that would prove difficult, so the RB25 in my Sil80 was the next best thing. BUT that engine is already producing 430rwhp with fantastic torque, and really, how much power can an S13 chassis really put to good use?
So the S13 got the nod and the build started. Went thru 3 RB30 blocks before a suitable one was found. I guess there's nothing overtly special about this build compared to the many others, except it's mine!
RB26 head, light port, decked, CC'd chambers, performance springs, standard valves, stem seals, seat pressures etc etc
Tomei 260, 9.1 cams
Adjustable gears
Custom fuel rail
Head oil return to sump
Siemens 870cc injetors, 2 pintle design
Sard FPR
Cometic HG
GTR pleunum and throttles.
Head Restrictors and enlargend oil returns
Block xrayed, decked and internally painted, welsh plugs etc
Spool rods, ACL pistons 9.0:1 comp ratio
ARP head bolts
ACL bearings
Crank polished and grub screwed
Ross balancer
N1 oil & water pumps
Jun crank collar cryo treated
Enlargened RWD sump with baffles & doors
Now i did have a GT3540 0.82 ex housing but i lent it to a mate to diagnose a problem he was having with his car, which it fixed so i probably won't bet it back :blink: SO, i can either continue this route, or go twins. I'm leaning towards twins and a set of 2530, be it HKS preferably or -5's
Designed to be a time attack engine so response is paramount. There is only a few with twins that i can find.
Here are some pics, not many but you get the idea
Edited by Simonster
https://www.sau.com.au/forums/topic/268005-rb2630-build-yet-another-one/
  • Replies 277
Posted Images
Nice one
3540r would be great response and powerwise for what you want, the -5's would be aswel of course but i think you'll find the single easier to work on and setup
Its strange, i've just sat down and did all the calculations that Garret use on their website to determine the most suitable turbo for your application and the 3540 doesn't flow enough air for my target hp. Which is strange as i thought 600hp (at the engine) would be achievable based on what others are getting with the 3582. But the numbers don't agree?
They don't have any calcs for twins though :banana:
But, i have a gut feeling the 3582 would be ideal. i have found some HKS2530 with standard ex manifolds that have been extrude honed and ceramic coated plus trust front pipes...mmm both my top 2 picks, which one to choose?
I agree, the single is no doubt cheaper and easier to work on, am unsure which way to go. I just keep thinking of the Mines R34 GTR, that thing is an animal with 2530's.
Turbo selection isnt the sole reason the Mines R34 is quick :ninja:
35R i would still choose; easier to work on, cheaper etc. But yeah, buy the 2530's and all that other gear for when you do get a GTR.
You're going for time attack, dont go overkill on the power - wheelspin doesnt make you fast :banana:
My old single setup is on an rb26 powered S15, making within 2rwkw of what my car made with the same turbo, its on full slicks and definatly doesnt need anymore power as it struggles to get it to the ground already in so many places where my gtr could just hold it flat and pull away. The S15's old setup though (R34 N1's) was deadly out of corners but ran out of puff on the straights.......tough choice you've got ahead if you really need 600hp. Have a look at the regs for the time attack you'll be entering regarding tyres and work around the tyres as the weakest link, as you know already, S chassis's cant just cop bucketloads of power and get it to the ground :)
Turbo selection isnt the sole reason the Mines R34 is quick ;)
You're going for time attack, dont go overkill on the power - wheelspin doesnt make you fast :P
My old single setup is on an rb26 powered S15, making within 2rwkw of what my car made with the same turbo, its on full slicks and definatly doesnt need anymore power as it struggles to get it to the ground already in so many places where my gtr could just hold it flat and pull away. The S15's old setup though (R34 N1's) was deadly out of corners but ran out of puff on the straights.......tough choice you've got ahead if you really need 600hp. Have a look at the regs for the time attack you'll be entering regarding tyres and work around the tyres as the weakest link, as you know already, S chassis's cant just cop bucketloads of power and get it to the ground ;)
Hey Steve, Yes i understand re the Mines 34, i was generalising.
Nice re your S15, there aren't many S13's here in Brissy that do time attack. I run mine on semi's. You are right though, i don't need 600hp although the work done to this engine isn't fully utilised unless i go at least another 100hp over my RB25.
This isn't aimed at you...It funny how people complain about wheels spin and how "my engine just lights the tyres" i don't find that at all, but i've always been able to control the engine power with throttle without any drama?
Well, guess what, ive put a deposit on a GTR ;) NOW i have another problem. This car a decent engine N1 block and seems to have decent bits in it. Just need to decide whether to keep the 26 in the GTR or drop the 30 in. It'll never see the track, it'll be my daily driver.
Anyway thanks for your input! I'm planning on coming down to Eastern Creek laster this year in the S13. Be good to have a go on a track that just doesn't have mainly right turns!
When you come down here send me a PM, ill head out to EC with the GTR for a bit of comparison ;)
Throttle control can of course stop that sort of wheel spin, i agree, still this S15 (not mine btw, good mates) lights up full slicks without issue even when trying to be careful.
Nice one on the GTR purchase! Got pics? For a daily driver, and if its already got the N1 block, keep it 26 but id be putting the 2530's on asap and getting a good tune :P
I always start these sorts of builds but pull the pin when i get scared of the dollars :P I ditched the idea of single and went to a 26 head so i could easily run 2530s so i could make a nice meaty 350rwkws with a bit of fuel and boost in 4th and 5th i may be able to jump it up to 370-380rwkws for places like Phillip Island and Sandown. LOL i am now selling the 26 head and other bits i had started to collect.
Will be interesting to see how a good RB30 goes in an S13. I cant help but be scared of RB30s and be concerned that they have too much grunt/torque for cars trying to go quick. There is that lttle devil on my shoulder that says rotors are so quick at the track as they are light and make good power with revs, but dont turn tyres with low-mid rpm torque. So i m sticking with less torque setup and hoping for some mroe revs and power up top
Real keen to see your results!
That's interesting Roy, i've watched your trip around PI a number of times on youtube, just loved it. For a guy in QLD, its quite hard to get to PI, but am aiming for Eastern Creek.
I'll keep the RB25 for a little while, still to decide if the 26/30 will go in the GTR or the S13. I really don't know. gotta board a flight to Hawaii
Cheers
Now i did have a GT3540 0.82 ex housing but i lent it to a mate to diagnose a problem he was having with his car, which it fixed so i probably won't bet it back :happy:
Haha, some how I don't think you'll see it again.
Awesome build Simon, an extra 100hp in the 180 would be nuts, throw it in the GTR I say and give me the 26 :P
Well if you ever head down there is always a bed available for interstaters :P
Thanks for the offer Roy, i appreciate that!. It'd be good to catch up with some of you fast guys in Sydney to pick your brain, as i still have a lot to learn
haha simon...mate we got alot of catching up to do! We are back in the game again :P
TWINS! You know you want too! Just do what mark and russ have done.
Hey Michael,
Great to hear you're back again. I've taken aim at your sprint track time- I know i won't get it but hey you have to set your goals high :(
Yes, i am leaning towards twins, it is the more expensive option, the 35 is a tried an tested route and will probably be the 2nd option if the twins fall though or $$ become the limiting factor.
I have an upgrade for thesplitter, this will really improve the front grip- this is an expensive route, but i know it'll work. Just have to convince the miniser of Finance and Sexual Relations :blink:
Russ's car is a monster, I'm not even in the ballpark when it comes to that
I'm in Hawaii, home in a week, with a new/old GTR sitting in the garage.
Hope to catch up soon- Time Attack 19 May QR?
put the 26/30 in the GTR simon. :(
AWD plus the added torque will make for a pretty nimble little car
Hey Mitch,
Yes i may well do that and sell the GTR engine....mmmm N1 block, almost can't believe i'm considering that :P
How's the 31 going??
Edited by Simonster
I thought you'd want the 25?? The 26 is putting out 330ish kW on 16psi though
geez....your not far off it though, a 57.3 is pretty damn good...but the next time attack is where it will be at! Hopefully see how everything will go. I think the next time attack for us is in july or thereabouts? Car isnt in a running state atm. But will be by then.
So its settled, 26/30 in the sil80, twins and about 400rwkws and go do 52's on the sprint track! Ill lend you some slicks to do it if you want :)
Hey Michael,
Great to hear you're back again. I've taken aim at your sprint track time- I know i won't get it but hey you have to set your goals high :D
I have an upgrade for thesplitter, this will really improve the front grip- this is an expensive route, but i know it'll work. Just have to convince the miniser of Finance and Sexual Relations :)
So its settled, 26/30 in the sil80, twins and about 400rwkws and go do 52's on the sprint track! Ill lend you some slicks to do it if you want :D
Settled, hardly. I have to sit down and have a very serious chat with myself about which way to go and what engine goes where...strange problem to have though!
Your kidding right, there's no way i'd go under 56.xx on semis.....slicks would be another matter though :)
Realistically, I think a 56.7 is possible if i get everything right. I've fixed a break problem the car has had for a while but, just waiting for a dry track so i can test the new limits....been out in the this year, twice its been wet, beat the AWDs' too :) They weren't happy about that i can you
So what changes have you made to the car?
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
