Hey guys.
After cracking the PS2 back out and playing Gran Turismo again. Interested to see what peoples best times are. Ive been working on mostly time attacking Tsukuba.
I just cracked into a 41.9 with the formula gran turismo WITHOUT altering power or weight. And im interested to see how that compares to others. Also particulary interested in times people can get in other cars (with no restrictions, i.e qualify tyres and Nitrous are ok).
Luke
https://www.sau.com.au/forums/topic/268071-gran-turismo-4/
  • Replies 103
Lol. 2 of my worst tracks besides the city circuits (just dont like them).
I'll do a bit of work on the Nurburgring with a stock 95 R33 GTR Vspec to see what i can come up with.
(using street soft tyres). Road tyres irritate me. It gives me the feeling of taking a car to the track with the spare tyre and stereo still in the car. (In otherwords. Why would you?? :P )
Still interested what people are getting on Tsukuba. I love that track. Surely there are other fans out there.
https://www.sau.com.au/forums/topic/268071-gran-turismo-4/#findComment-4571205
Haven't really run the Nurburgring properly but I got addicted to the Tokyo Route: 246 (Normal) track.
Car was a 2002 Honda NSX-R with stage 2 weight reduction, R2/R2 tyres, no nos and horsepower rating of 484bhp (maxed). I managed a best of 1:29.925 after 10 or so attempts. If anyone has beat it then let me know, cause i will pull out the old ps2 and try to better it :D
https://www.sau.com.au/forums/topic/268071-gran-turismo-4/#findComment-4581155
  • 4 weeks later...
Car was a 2002 Honda NSX-R with stage 2 weight reduction, R2/R2 tyres, no nos and horsepower rating of 484bhp (maxed). I managed a best of 1:29.925 after 10 or so attempts. If anyone has beat it then let me know, cause i will pull out the old ps2 and try to better it :)
gotta say man, that is a f**king good time. the best i could manage with that setup was about 1:33 (but i only did about 6 laps). i had to go to stage 3 weight reduction and qualifying tyres to get into the 1:29's (which it only took me 3 laps to do, LOL)
https://www.sau.com.au/forums/topic/268071-gran-turismo-4/#findComment-4651719
Lol. yeah it took me awhile to get it down to that time. When I said 10 attempts, I meant in 10 different sittings (each sitting could've entailed around 10 laps each try), so it actually took me like a few weeks. Reason why I didn't go nos, stage 3 weight reduction and qualifying tyres was that a 1:29 was very hard to do with that setup so it was a pretty decent challenge, hence why I kept at it until I got it under 1:30. I've still got the replay for that time saved onto the ps2 memory card if you want to check it out. I'm not sure how to get it from the memory card and upload it on to here though. Any ideas?
https://www.sau.com.au/forums/topic/268071-gran-turismo-4/#findComment-4652982
Ugh, worst car I've used on the game period. So impossible to judge and super twitchy with loads of understeer. 1:32.346 was best I could manage. Tokyo sucks too :P
Nurburgring FTW
You'll have to tweak the suspension and downforce settings etc until they're perfect for your driving style if you want a really good time on that track. Took me a while to get all the settings tuned for high-speed grip and stability as well before I could get anywhere near that time.
https://www.sau.com.au/forums/topic/268071-gran-turismo-4/#findComment-4653574
now you tell me, LOL
i didn't use nos at all. i will have another go over the weekend sometime. i didn't really play with suspension setups at all.
will have to buy another car since i have done stage 3 weight reduction now. or i will just try and beat it by a decent amount to make up for it, LOL
i used to do the tokyo track all the time in the xr8 v8 supercar a few years back. that was on gt4 prologue. i worked at toyworld and we had it on a demo machine so every afternoon after we had packed up i would do a few laps while the cashup was done. used to be able to do sub 1:30 in it..... i think, LOL. that was about 6 years ago now.
https://www.sau.com.au/forums/topic/268071-gran-turismo-4/#findComment-4653698
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
