my sets of wheels
1st- AVS model 5 17x8/9 cant remember offsets federal 595 SS tires
2nd- Panasport G7 17/8.5/9.5 cant remember offsets stretch wanli tires
3rd- Enkie ?? pair 16x7 yokohama DNA GP tires
4th- TE37's 17x9 +20 Dunlop 03's
5th- Enkie NT03 17x8/9 +32/+15
6th- Work Emotion CR Kai 16x8 +30ish random tyres
7th- TE37's 17x9 +20 RE55's
8th- Weds Sports SA70's 18x10 +18 Bridgestone RE050A RFT fronts Michelin
Pilotsport RFT rears 255/35/18 all round
9th- Work Equips 18x10/12 -16/-9 something Bridgestone RE11 245/35/18 fronts no
rears yet..
loved every set :)
Axis Hiro:
You won't get as much dish on a GTS-t, but they designed the Hiros to get deep dish so even with a relatively weak offset you should have some.
Lenso D1R (aka Project-D):
Yes, the Lenso D1R won "BEST WHEELS" Award at the 10th Anniversary R34 GT-R Celebration last year.
For thinner spokes > Rays RE30 with Titanium face & Satin Silver dish.
That fitment is awesome, does it scrub it's balls off at the front?
Respect for having the knackers to go with some decent fitment and not make your 33 look like some limp wristed, sunken wheeled, wally-mobile.
Watch out for the fun police too! They'll be along soon to tell you it's impractical/your tyres are too thin for a 10 inch wide rim.
thats ur opinion, the car will prob never see more than 235's on these rim for drifting, which is what the car is built for..what part of it makes it impractical??? if i was track racing id have different size rims and tyres...whats the problem,
anyway the car looks great and the rim/tyres fill out the guards perfectly, like i said there's a bit more camber in the back so the rim just barely sticks out compared to the pic..and there is not rubbing on the front either :laugh:
I have a feeling the comment was a gee up, hence why it was a direct copy of my fun police warning.
235's on a 10" arent the end of the world, for the most part 235's have SFA stretch on a 9" so on a 10 should look toasty.
Legalities aside that is.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
