i don't need the extra power. Just chucking these in because I can :)
I also love the fuel economy my car gets, i got over 230km's to half a tank yesterday lol - would rather keep it is mild as possible
Ahh its not so much about picking up extra power its making the same power with less boost. :mellow:
Not an issue with E85 but definitely with pump as you run in to det issues well before your able to crack MTBT.
Fuel economy with mine is around 450km's per 50liters and I don't baby it. :)
Interestingly if I do baby it there's bugger all difference in economy.
I got a phone call today from Boost Magazine! The cams have arrived.
I went to pick them up !!
I would like to thanks the guys at Kelford (cams look awesome!!!) and of course Boost Mag, you guys rock my world!
400+rwkw here i come ;)
Is that you and your car in boost Anthony ? I assumed so since adrian did the article ? (With the gizzmo Kmon) ??
Yep, sure was. He's a media personality now. I've made him a star!! LOL!
I dug what I read about the K-mon so much that I had to find someone with one and old-mate Pauly-D-Twoogle steered him in my direction.
Stoked, but I hope Anthony doesn't become a diva now with his new found fame!?!
Which cams did you end up getting
I got the 264 with 9.35ml lift. Will do away with the VCT as well. will be very interesting how it goes. I will do a before dyno run and after run and send the data back to Boost magazine and I hope they will Publish it again.
This fame and attention i have been getting is addictive!! i hope they publish it ;)
Ha-Ha cheers also from us and Gizzmo, ray will be stoked. The k-mon is well regarded overseas (UK and USA) but receives little feedback here... good to see it got the well deserved plug. Ive been using it for years and was stoked when anthony wanted to source one from us as i knew it would take his tuning a step further.
I really dig it. I hope Ray feels the love too. I told him i'd do a story on it but i'm not entirely sure he believed me.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
