How many RWKW will Nismo 555cc injectors make safely?
47 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi Fellas,
I currently have 312 rwkw and the injector duty cycle is at 81% (using nismo 555 cc injectors), without a FPR
My aim is to get my power up to 360-370 rwkw. Using basic extrapolation ((0.81 x 365))/312)=94.7%), I get an injector duty cycle of around 94.7%.
However, if I install a Fuel Pressure Regulator (FPR), I will be able to increase the pressure, thus, making the injectors flow a bit more.
Anyway, I need you opinion on what power you think the injector's would max out using a FPR with my 555cc injectors.
My tuner is very confident they will make 360-370rwkw safely, as he has done it before.
Please place your vote!
Cheers
You dont need to bump something 45mins after you last posted in it dude...
Just be patient.
Your vote would be greatly appreciated!
Weren't you runing like 365 watts in your R31? What size injectors were you using?
I already have voted.
I used 740's - i knew the power i wanted, so i purchased injectors to suit it. :happy:
Im not a fan of FPR's if you've gotta buy injectors, you might as well buy the correct ones as i see it and use one of the better Nissan OEM parts.
For what you need, it'll be fine however to add in a FPR, bump a few PSI and make what you need.
without bumping fuel pressure your 555cc's would probably max out at around 330-340rwk
So generally speaking, how much more power does a FPR provide?
Also, are there any disadvantages to having a fuel pressure rgulator over bigger injectors? (Does it increase the chance of damage to the fuel pump? Or increase the risk of split hoses? Can a FPR damage injectors?)
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
