I don't know of any twin entry T3 , Euro T4 , GT30 turbine housings but the non gated one I see most is the GT32 plain bearin one - search for GT3267 in 0.78 AR .
The only real GT30 TS IW housings I know of are the Evo 10 ones but they have a different mounting flange .
Possibly the best response GT3076R (IMO) would be the 52 comp trim one with a 0.63 AR GT30 turbine housing .
If it were me the 0.63AR with a good smooth up job in the turbine housing and maybe exhaust manifold would be good enough . I dunno about a lot of boost at 7500 but more that enough to be a tractionless pig in a RWD car with the boost turned up .
If you could go inside the engine and fit a tad more capacity ie 26 crank and 1mm over pistons it all helps . I would touch anything under 9.3 to 9.5 static CR and Poncams don't go astray . Then just bolt a 56t GT3076R on with the 0.82 housing and tune the thing properly .
On the cheap , a std freshened up RB30 short and if you could spare the cash higher compression pistons .
My conclusion is that twin scroll systems are either too expensive or too defectable on single turbo Skylines so tried and proven single scrolls and extra cubic inches end up being easier .
A .
Disco, could you give me your opinion on 8cm to 10cm turbine housing with a 1:1 increase in CR? On an SR.
Am thinking would possibly make for a better driving car than not.
Why dont you just get a Garrett EVO9 replacement twin scroll GT3071 or 3076 with internal gate.
You will find that the 0.76AR TS GT3071 will spool about the same rate as the 0.63 GT3071 but the power will be more - ie closer to the 0.82. Twin scrolls are about broadening the torque curve.
My pick for 280rwkw with the rb25 would be the TS GTX3071 with the 0.73A/R. I would expect that power at 15psi with full boost around the 3000-3200rpm range.
Lol is this a stab in the dark? As that information is also inaccurate. Twinscroll generally makes more midrange and less topend vs openscroll.
Probably the EFR 7064 will fit the bill.....if it ever gets released. The EFR 7670 seems to be between the GT30 and GT35 - so too big for you.
AND you can have either single scroll (T3) or twin scroll (T4) with internal wastegate. No need for external wastegate.
Edited by simpletool
8-10cm housing on what ?
I thing the Garrett GT28 based turbos are the go for SR20s , either the GT2860RS or any but the biggest trim GT2871R . The reason being that they use either a GT25 or GT25 BB turbo std so the GT28 ones go on easily enough .
I'm not really an SR 20 person but if I was it would have the early high inlet port non VCT head and the GTiR four throttle inlet manifold .
A
  • 5 weeks later...
Very weird looking dyno plot, looks more like a torque plot than a power one. Torque must absolutely nose dive after peak boost.
Solid line looks like torque....dotted line is power....albeit in PS so would read lower in KW's.
Edited by juggernaut1
The curve is a lot less steep than some because its not a peaky power delivery ;) It'd read less in kw, but its still at 280ps (208kw) by around 4000rpm and reaches 526ps (390ishkw) which makes for a pretty impressive spread of grunt.
Going by this dyno plot, a GT3582R with an ATP T4 1.06a/r twin scroll turbine housing will more or less hit the magical 200kw by 4000rpm mark on an RB25:
That is predicted flywheel ps and not wheel ps. So take off a fair whack of power everywhere :thumbsup:
As my above post realistic figures are probably more like 165kw by 4000rpm and 310rwkw :cheers:
So it is different from other dyno sheets? Aren't they all predicted hp?
Or do you mean theyve inflated it to give flywheel hp instead of wheel hp? What would be the purpose of that?
So your saying that PS = BHP not WHP? Can't it be either it's just a unit of measure and the graph doesn't say where the power was measured.
PS
This unit (German: Pferdestärke = horse strength) is no longer a statutory unit, but is still commonly used in Europe, South America, Japan and India especially by the automotive and motorcycle industry. It was adopted throughout continental Europe with designations equivalent to the English horsepower, but mathematically different from the British unit.
DIN 66036 defines one horsepower to lift a mass of 75 kilograms within one second against the earth gravitation over a distance of one metre.[10] Similar definitions were already common to the time of James Watt.
The PS was adopted by the Deutsches Institut für Normung (DIN) and then by the automotive industry throughout most of Europe, under varying names. In 1992, the PS was rendered obsolete by EEC directives, when it was replaced by the kilowatt as the official power measuring unit. It is still in use for commercial and advertising purposes, in addition to the kW rating, as many customers are still not familiar with the use of kilowatts for engines.
Edited by D_Stirls
yes but either way I think you've mixed up the lines. dotted line is power for sure. other line would be boost or possibly torque. it's only hitting 250ps at 4000 RPM which is around 180kw. I agree it's probably at the wheels. it's pretty good but not super awesome.
If you look at the power axis you will see that it is referred to as S_PS
The "S" represents predicted flywheel. So any Dyno Dynamics graph with S_HP or S_KW etc is predicted power at the flywheel not recorded power at the wheels.
The guys from the UK tend to use it a lot... See below as an example, this is a stock RB25 turbo on a RB25 running 12psi (which would be around 270rwhp normally)
Not sure who that is directed at, I knew the dotted line was power.
The 4000rpm line is a bit hard to nail down exactly, but at 4140rpm it looks to me to be sitting at around 294ps (216kw) which is fairly stout in my books.
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
