Hi Guys,
I just got the flow bench test results back for my front facing plenum. This is a custom plemum that bolts on to the standard runners.
Since there had been a bit of a debate over front facing plenums and my engine is being rebuilt, I took the opportunity to get it tested.
I know this is a static test, on a flow bench so it doesn't represent exactly what is happening in the head with valve movement etc - But it's a good start for a bit of empirical analysis.
1 275.4 cfm
2 283.1 cfm
3 307.2 cfm
4 272.4 cfm
5 277.2 cfm
6 298.3 cfm
(1 being front, 6 being rear - Throttle body = XF)
So I am getting a 34.8 cfm difference between 3 & 4 - Which is interesting as one might speculate that most of the flow goes to 5 & 6.
BTW I am no engineer - but 11.3% difference in air flow betwen runners seems a lot to me ??
Has anyone got any comparative bench flow tests for standard or GReddy/Trust plenums ?
Now I gotta decide what I am going to do about this -
a) Try and fix the current plenum (a bit hit & miss)
B) Replace with standard plenum
c) Replace with after market (Trust/GReddy)
d) Just keep in and richen it up a bit
Opinions and feedback welcomed folks. Keep in nice though OK ?
Cheers,
  • Replies 57
  Quote
Originally posted by elbee111
Why would it flow in a sawtooth ascending 1-2-3 and 4-5-6??
Interesting.
Might have something to do with the shape of the plenum ??
Any pics of the internals?
On an RB25 if you remove the top half of the plenum, are all the lower runners the same length?
On an RB20 the runners are only the same length when top & bottom halves of plenum are bolted together.
Ie say runner no.1's top sectoin equates to say 50% of its length and so does the bottom section. On runner no.6 though top section equates to 65% of runner length, and bottom equates for the remaining 35% of length (rough numbers only).
So if you only use the bottom section of the plenum then some runners are shortened by 50% others by 65%... making sense?
Roy - by sight, they all look the same length.
Anyone got a standard plenum (the top bit only, not runners and all) and I will get it tested for a side by side comparison. Can use my runners etc - The test wasn't that much, so I'd be happy to pay for it , if someone donates the standard plenum....... I might even buy it off you , if the results are good !
Cheers,
sidewaymambo & B-Man, that would be excellent to do a flow test in the same way on the standard plenum. As we know, a number of guys have problems with no 1 and no 6 cylinders (possibly due to fuel reasons as well) but to have the baseline flow data would be excellent.
grepin, if you read this you should invest in flow testing your Greddy plenum whilst it is still off the motor.
  Quote
That's exactly what I am thinking..if someone can lend it for test..I wish ..
Sidewaymambo & I have just spoken and I'll pick up his standard plenum on the weekend -
So I'll get the same people to do the bench flow test on it and then post the results back !
Thanks Phillip !
Good stuff ! :rofl:
B-Man when you pick up the plenum dont be tempted to look under the bonnet of sidewaymambo's car...mmm very strong is the power of the darkside (in my best yoda voice):(
...and great work for the trouble your going to, a case of Crownies for the man!
No way man ! I'll look after it - I promise !
Does someone want to donate a GReddy Plenum ? And I'll get that flowed at the same time .. . . I promise I won't put it on my car and give you back my old one.... he he he joking !
But yeah, I am serious about flow testing a GReddy if someone else is willing to help.
Hi B-man it is good to have someone confirm our on car results. But be careful, how a manifold reacts (flows) under vacuum (ie; on the flow bench) is very different to how it flows under boost. Did you do it at 1 bar or 2 bar vacuum? We find head flowing for a turbo engine gives more boost friendly results at 2 bar vacuum.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
