Vid for those interested.....yes it is a Civic
Taken at Eastern Creek at Superlap
Fastest NA Open
Fastest FWD Open and Outright
8th Outright Open
Time 1.40.94
http://www.youtube.com/watch?v=0dnQW9MT-no
180sx at Carnell Raceway, taken with a panasonic DMC-FT1
nice aleks! Carnell is such a fun little track
here's an in-car vid from my 180 at Lakeside yesterday. Another 4 tenths off the PB with some setup changes and cooler conditions. The standard viscous LSD really isn't up the the job! but even so i don't really think I should be getting this much wheelspin with 240 wide rear slicks. Last time out, and the first time I used the slicks, I had so much traction it was boring - may as well have been driving an Evo :) But not anymore. Think they may not like the constant heat cycling? They seem to be taking longer to come up to temp too, but it was a much cooler day... Anyway, here it is. Lap 3 is a 58.9 :P
I went to Wakefield Park on Monday and after taking me an hour to start my little car (-4c on the trip down froze the poor little bugger) I eventually managed a new pb of 1:12.7 down from 1:14.4 with tyres that have seen 4 trackdays.
It was my first time using the PerformanceBox GPS laptimer and datalogger which was a massive help. Knowing your split and laptimes as you go is really good information.
I've done a speed comparison on my best and second best times of the day and their is no more than 3km/h difference at any point in the entire lap. The difference between my 12.7 and driver trainers 12.0 is no more than 6km/h however I did have better mid corner speed in some corners than him but he tended to brake earlier and get on the power earlier out of the corners.
Here is a video of my fastest lap of the day:
I haven't got the TrackVision software working yet but my top speed on the straight was only 160.9km/h :D I really need to work on turning in later on the last corner and deeper under brakes on the first corner.
Here is a picture of my lines for this lap based off the gps co-ordinates:
I haven't got the TrackVision software working yet but my top speed on the straight was only 160.9km/h :) I really need to work on turning in later on the last corner and deeper under brakes on the first corner.
Have you had a look at the lines the trainer used when running your car around? Any significant differences?
nice meeting you out there too.
my previous best in NA 120ish rwkw form was a 1:09.8
as run in the vids, maybe 260ish (only running 1 bar) and first time at wakefield with turbo 1:07.7's.
to be fair, the 1:09 was done on pretty old r888's, the above vids were on new re55's
There's more in it
Edited by badhairdave
LOL, just curious to know what difference power made to the lap times. I am always on the prowl for a good R32 or S13 Silvia as the basis of a build up...but being OS means it has to really be a good buy to throw into storage for when i get back. My dirty2 is not getting any more mods after the RB24. Nex car is going to be so stripped it will resemble something from Mad Max 2 :)
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
