I recorded the following 0 - 100kph times using a GTech pro RR device (settings RRR):
Automatic mode with launch control 3.764 seconds -flat surface
Automatic mode with no launch control 3.900 - flat surface
Manual Mode with launch control 3.820 -flat surface
Manual mode without launch 4.064 - uphill
This is for an ADM, premium, 22 degrees.
Tests were conducted at the track.
When the HKS 570 kit and Cobb custom tune (Croydon racing developments) are installed next week, I will post the enhanced 0- 100kph numbers for comparison purposes.
https://www.sau.com.au/forums/topic/270400-0-100kph-times/
  • Replies 86
wow, quicker than both Motor and Wheels who couldn't crack 4.0 secs. Why are they so slow, when EVERY single acceleration test around the world regularly yields 0-60 mp/h times in around 3.3 sec and 0-100 km/h between 3.5-3.7 secs?
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4600450
Wow! Will be interesting to see the future results!
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4601844
the nissan dealer told me if i used the LC for twice or more, it will damage the transmission/clutch, which will cost big bucks to replace.
but it seems like everyone here is not too concern about it and keep using the LC.
any feedback????
I think you'll find that's scare tactics. My dealer has been quite reasonable about it. Unlike LC1, LC2 seems to be reasonably easy on the car - that said I've only done it twice, and wont be using it at all with the modifications.
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4602186
I have not timed mine yet using GTech or equivalent but had a few races against my brother's 997 911Turbo, Auto, (the faster one), with overboost engaged. (680Nm instead of 620Nm for 10 seconds). Carried out on a closed track. Using walkie talkies to countdown to the start made for a very unscientific starting process and each of us would win the start on different occasions making for some varying results.
1) 911 stalled to approx 2000 with gentle throttle and GT-R stalled to 2500 with partial throttle. 911 won start by a car length, (due to me napping at the get go), GTR had passed it by 100 KPH and was a car length ahead at 150 KPH.
2) Same conditions GTR won start and pulled ahead by 2-3 car lengths at 150 KPH.
3) Both cars launched with no brakes whatsoever, just floor the accelerator. GT-R leapt ahead by 2-3 car lengths and pulled away steadily.
4) 911 stalled to 2100 RPM with throttle floored. His boost rose to 9 PSI before we even started moving... GT-R again stalled "gently" to 2500 RPM so no "pre" boost to speak of there. I napped again at the start, or perhaps he cheated!! Lost start by 2 car lengths and maintained gap to him to around 100 KPH but did not reel him in at all.
I had 1850 kms on the clock, his car 10,000 kms. All my tests were done with VDC set to race and Suspension to comfort, in Auto with trans set to race. I didnt disengage VDC and it still allows the revs to rise to over 3000 RPM so why bother disengaging it? VDC in race mode does not cull engine power if traction is lost. I didnt have the fortitude to do a 3000+ RPM launch with both pedals floored......yet
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4603192
With just 1150km on the odometer and K&N filters installed, my GTech Pro RR results were not as good as yours:
All 3 settings on R, no launch control, stall to 2500RPM (electronically limited!), floor the gas and step off the brake: 4 runs:
0-20m 2.552 sec, 0-100kph 4.344sec
2.575 4.377
2.542 4.316
2.560 4.351
The first second and a half after launch it feels like stretching an elastic band as the boost builds up and then all hell breaks loose. I am wondering if the brand new clutches need to bed in more because it feels very laggy from a dig, until a second or two after launch when it goes berserk. I never got a hint of a wheel spin on smooth new asphalt. Also, the engine may still be a bit tight?
This car is definitely a rolling start king but from a dig, without launch control, it's not setting the world on fire.
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4618228
I've heard so much inconsistency with pricing in Australia for this new GTR, and there has been some discussion over another forum about ...
_______________________________________________________________________________
Acne Adult Medicine Cure
wheelchair lift
And how is the pricing policy going to improve the 0-100kph times?
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4618919
2.575 4.377
2.542 4.316
2.560 4.351
I've been told the standard airbox is better than the aftermarket job, I certainly had this problem with my EvoIX, it went faster with the std airbox.
Interestingly my 0 - 20m times were similar to yours. I had 2600 kms on the car.
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4624654
Thanks for the tip. The thought crossed my mind!
It appears that both cars have the same turbo lag down low, hence similar sluggish 20m, but yours has a better top end which could be due to the air box.
I will swap back to stock air filters and give it another shot at 2000km.
What was your max HP reading? Mine was only 265kW with 1830kg gross weight input.
Good luck with the HKS! :action-smiley-069:
Edited by GT-Ricer
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4625420
4.3sec-4.4sec 0-100km/h.
Seriously fellas, 370Z with a few mods would probably do that, or very, very close to that. For sure I know that an EVo-X would do 3.5sec 0-100km/h in FQ-400 guise. If my car is 30% slower than what Nissan advertised in 2007 and 2008, 3.3sec, then I would be seriously pissed of with them.
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4626857
I suspect the 4.3 - 4.4 second car is an exception. I was getting 3.7 easy, in fact each run was getting quicker. The journos managed 4.0 flat (without LC).
The 4.4 second car had an aftermarket airbox in it which probably slowed it down.
The JDM cars are getting 3.3 seconds because they are running 15 psi compared to the ADM 12 psi. And as you would know, that is very easy to fix. My gut feel is that these cars (even in JDM spec) are going to be easy to tune to big power without too many risks, which is no different to most turbo cars these days.
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4627099
Today I re-tested my car’s acceleration times over 5 runs after 1800km, with stock air filters in place for the past 500km.
My 0-100kph times ranged from 4.37ces to 4.55 sec. I tried everything and every combination: stall against the brake to 2400RPM (limit) ; step of the brake and hit the gas. No real difference.
My car engages quite well and after 10-20m or so it bogs down for about 1 sec before taking off again with real momentum.
It refuses to accelerate from a dig in a linear fashion.
This bog-down happens in first gear so it has nothing to do with a gear change.
It seems that after the initial launch something in the ECU shuts down or retards the timing, before it resumes on its ballistic trajectory.
I spoke to Mathew at Col Crawford who will be doing my first service next Wed-Thurs. We will go for a test drive and also compare with the demonstrator car.
It’s a real disappointment so far!
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4650647
Today I re-tested my car's acceleration times over 5 runs after 1800km, with stock air filters in place for the past 500km.
It's a real disappointment so far!
I hear you.............
https://www.sau.com.au/forums/topic/270400-0-100kph-times/#findComment-4650903
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
