Hope its running a stroker kit and throw a set of R32 GTS4 diff gears at it; she will need it. :P
I came across a bloke that makes 4wd adaptors for the LS1 block to suit Patrols as well as gearbox adaptors.
Surely it wouldn't be too hard to rig something up for a light LS1 in to an R32 GTR. Strap on a turbo or two; now that would be fun. :)
Edited by SLAPS
plains for the car are maddat roll cage, origin body kit then giv it a lick of orange paint
the next part will be to get the motor together which will been build by TURBOTUNE, which will be a redtop sr20det with tomei camshafts, tomei cam gears, scat rods, arai pistons, a trust L2 turbo kit.
hopfully were able to get the motor in with out to much touble but will post up pics of the build as we go
please keep this thread clean an postive
interesting choice, why?
well first i was gonna b using a ke70 shell but i just couldnt find one cheap enough an clean enough an yeh came accross this shell an it was a bargin an thought it would b somthin different an catch a few eyes when its done
haha thats fair enough then... will be keeping an eye on this.
yes im curious, why not used a tried and true motor instead of smaller displacement and less turbo's?
sr20's can make a fair whack of power too, just setup differently i guess. still an rb25/26/30 will give you a much better kick down low where you will need it for hillclimb especially.
at least youll be taking a bit of weight off up front :P
Edited by SkyHi_33
Shouldn't be to hard a car to build, its been done plenty of times before, I've got a mate putting a SR in his ceffy. keen to see it in action.
Do you own the Hilux with TONKA on the plates?
thats alot of weight for a sr to pull, interesting none the less
actually if he chucks in the RWD front cradle and does away with transfer case it will weigh less than a standard R32 RWD car
GTR's are only heavier due to transfer case and extra front shafts CV joints and all the bits and pieces to make em AWD
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
