anyone who can help me would be great.
just wanted to know how much power can u lose on a dyno reading due to having big rims on the car. i was told u can lose 15 to 20kw!...... is this right or shouldn't it make that much of a differance.
thanks..
thanks..
I recently took off my 17" Volk AV3's and temporarily fitted 18" Speedy Cheetahs and noticed a slight power decrease. I'm guessing that's due to the Japanese rims being lighter in weight. Wasn't very much but certainly noticable, so should be the same during a dyno run? I'm replacing those Cheetahs with Gram Lights next month anyway so hopefully I can reclaim that lost (1.5kw? >_< ) power.
the wheels will add load to your hubs, which might make it marginally lower, but the kW difference should be negligible... however the added weight of the rims and the lower profile tyres will affect your handling much more noticeably.
Also maybe people who run bigger wheels opt for cheaper/less grippier tyres, and therefore on a dyno there's more slip?
So what ur saying is differance wise on the dyno it should be a little differant. It won't be a massive difference like 20 kw! LOL if u got 20"a on the car compared to the stockys 16"s can u lose 15 or even 20 kw atw if say i pull the 170 kw mark on the dyno.
so will i be ghey if i roll up in a stock r35 with stock 20s?
LOL!
an r35 gtr comes with 20" wheels stock so it wouldn't be ghey at all. however a 33 or 32 gtst with aftermarket chinese 20"s = ghey + chinese made - coolness = fail at life so jump off a bridge.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
