I just found out my manual turbo r33 that I just bought was a converted AUTO. It has the the auto ECU, and looking at the specs the auto makes less power then the manual. Can I swap the ecu for a manual one or are they the same?
I think it still has the auto 4.4 diff also.
https://www.sau.com.au/forums/topic/271517-r33-auto-vs-manual-ecu/
known differences
- dash cluster
- ecu
- diff gears
- turbocharger actuator
the auto runs less boost (lower rated spring) so make sure you fit a boost controller (or change the actuator)
from memory the auto runs about 4psi and the manual runs 7psi so definetly a difference worth fixing
known differences
- dash cluster
- ecu
- diff gears
I call BS on the boost thing. My auto GTS25T runs a solid 8psi. Factory ecu, factory boost solenoid (earthed to keep it at high boost).
  • 3 weeks later...
ran a auto ECU when i done my conversion for years. put a manual ECU in at the end of last year, the only thing it did is clean up the idle a little and a bit nicer power curve.
did you need to do anything special for the manual ecu? I mean did it just plug in and go ? and were you able to remove the auto computer afterwards?
just unplugged the auto computer and plugged in the manual. have got a SAFC2 and had that retuned on the dyno. if the car is stock, it shouldnt be a problem. just plug it in.
the auto acutator has a different spring, thus it runs less boost
i have seen this with my own eyes in an auto R33 GTST
i suspect they just made it run less boost to make it not as quick and attractive
and perhaps to make it more nimble when driving it? maybe those who wanted auto cars in japland didnt want fast ones?
i mean were only talking 2 psi, but its a bit of difference i guess
and if you would like to double check, in case you think im wrong (haha?)
then check the R33 nissan service manual
r33_engine_manual.pdf
page 173 of 491
or EN-153
r33 auto boost = 270mmhg = 5.22 PSI
r33 manual boost = 385mmhg = 7.44 PSI
crap -so i'm missing out on 2 psi?
that is ALOT if im only getting 5 psi.
My factory gauge reads about a 2-3mm below the middle line.
Suppose I should get a cheap temp boost gauge to check it , and if it low then get a bleeder.
thanks for the info guys
page 173 of 491
or EN-153
yeah this is exaclty what the auto does on max boost full load
on the stock guage it reads below the middle line noticbly below
the manual gtst goes above the middle line
its a fair difference
you would find it better to do basic stage 1 mods though...
exhaust
intercooler
boost to 12psi
interceptor device (safc, piggyback, remap)
the car will run loops around the factory setup
  • 1 month later...
im still not convinced. Is that manual for S1 or S2? Everything i have read, and tested points to the S2 (atleast) running 6psi/8psi factory boost, using the dual stage solenoid. Earthing that solenoid makes it run 8psi all the time. Thats regardless of if its manual or auto.
Ive driven two auto 25Ts now, and both have done 8psi (one is my own one, and that runs 9psi due to free flow panel filter, no other engine mods), and the other one had exhaust done, ran 8psi. The second one was a S2 sedan.
I havent driven a manual one yet, so cant comment on them.
Well my auto Stagea (RB25DET) ran 5lb and 7lb. Three suggestions for you:
1. [no cost solution] You can get 10psi by bypassing the solenoid altogether. Follow SK's directions and bore out the restrictor and you can get any psi you want (see post #40): http://www.skylinesaustralia.com/forums/Ja....html&st=20
or
2. [low cost solution $30 or so] get an RB20 actuator (they run 10psi)
and or
3. [From $200 - jaycar eibc plus hand controller like mine or up to $1000 for flash big name one] Get an electronic boost controller (not a bleed type which will be little better than #1 above) to build boost more quickly and hold it longer.
So does that mean there's no 2nd stage boost for an auto? My auto car hits ~5psi fairly quickly with just a bit of lead foot from standstill.
I have never fully floored it so I (never revved over 4,500 rpm) don't know if there is the 2nd stage boost or not, where it hits ~7psi.
thats good info( i didnt know about the no - cost option)
With the RB20 actuator, is that 10psi with the rb25 boost controller or iwith a direct connection to the inlet nipple???
thank for the info
or
and or
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
