Hey,
Just wondering if anyone has ever tried to put an rb26 gearbox into an r32 with an rb25. Reason for wanting to do so is, i have a stock rb20det gearbox in there atm and its not going to hold up the power its making. RB26 gearboxes are heeps cheaper than rb25 and I can modify it myself to RWD, i have done one before for a silvia conversion.
Just wondering if anyone knows where or not the gtr32 cross member will bolt straight up, and whether or not anyone knows for sure if rb26 gearboxes are stronger than rb25 ones? Also would a RB25 Nismo slave fit onto a RB26 box? Im assuming that all RB gearboxes have the same 2 bolt pattern
thanks for any help
https://www.sau.com.au/forums/topic/271700-rb26-gearbox-into-rb25-r32-gtst/
anyone?? Im gonna buy an RB26 gearbox and just give it a shot. Damm well hope it works. But some info first would be great if anyone knows anything
A full write up/tutorial on the modifications to gearbox would be awesome...please.
Only problem with a 26 box instead of a 25 one is that you know that the 26 will have copped a lot more abuse over its lifetime..
thats BS and means nothing....
if you gonna say that then you could say a GTR box will have been serviced better.
to be honest i think GTST's are driven harder than GTR's....
hmm. So you are trying to tell me that every japanese gtr owner actually serviced their gearbox, ever.. or gave a crap. Let alone factor in the added power and torque on the mechanical workings and the added load on the output of the 4wd system..
hell no.
but you were trying to tell me that no GTST owners thrash their cars!
i see where your coming from but there's way too many variables to be able to say that GTR boxes will be in a worse condition.
Hey,
thanks for any help
chur i put a r32 gtr box in my cefiro but i didnt cut the transfer case off so had to cut a hole in the gearbox tunnel for that the crossmember doesnt fit i got a custom made 1 and yea the slave is the same i used my 20de slave on mine abit of a tight fit but it does would of fit straight in if it wasnt for dat transfer case
you cut up your car befor the gearbox lol, your mad. Im hoping the crossmember will fit because its from a r32. I will post progress pics when i recieve the gearbox, just after the damn freight company stops stuffing around the little fella!!
i reckon everything will bolt up except the crossmember. i've just done my clutch yesterday and contemplated the same change your talking about - but i reckon it's risky. even though 26 box's are cheaper then 25's it's still a fair bit of money to risk buying then finding you need to mod your crossmember.
  • 8 years later...
hi good day guys. im currently doing this said conversion on a nissan c33, i got the shaft done yesterday but my problem is the bracket itself is too low for the car. i really dont want to cut my car to send the box higher is their any other options? the box works perfect and the ratio is heavenly just i can barely drive the car would some coilovers help?
This post suffers from not being at all clear what the problem is.  How would coilovers solve anything to do with how the gearbox sits in relation to the rest of the car?  And more importantly, what bracket are you talking about?  The gearbox crossmember or the centre bearing mount, or what?
  • 3 weeks later...
The gearbox cross member
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
