would also like to add, this is a r34 gtr with low km's. not very old. it would not be suffering from coil pack issues yet.
yes but it is 10 years old, and the engine is making alot more power than the standard engine, and the coilpacks just cant handle it anymore.
  • Replies 49
would it not be worth it to upgrade the coilpacks anyway... they are 10 years old, the engine is making 150kw more than standard... bakes has spent alot of the folding stuff on all this gear... even if they didnt need to be done, it would be a worth while upgrade.
what happens if he swaps some coils for someone else's... and the other person's cant handle the power and break down... then bakes is up for 2 sets of coils instead of one. the only way to rule out the coils is to get new ones.
Bakes
I am having the same issue as you with my car - exactly the same - will occasionally miss on or off load - and yes, sounds exactly like a WRX when started up sometimes.
The problem is pretty intermittent for me - and seemed to resolve itself after I replaced the plugs - then it came back again - but not as frequently or as bad.
I do find that once the car has warmed up a bit it will come good.
I've been pondering the Splitfire coilpacks or one of the HKS ignition kits as a possible solutions.
So let us know how you go on once the coils go in.
Bakes
Seriously man, I have to agree, sounds EXACTLY the same. Ive ordered the Splitfires today, Ill let you know how it goes. Might be able to put them in late next week depending on when they arrive at my door.
HKS use stock rb26 coil packs on the drag car. runs 7's ?
wow - i had no idea...i have a standard set on my gtr & another standard set from my previous aust delivered gtr :(
i guess i wont be upgrading for now if there is no real benefit other than age/wear & tear
I would suggest to try some ones elses coils first. I had a miss firing problem, I tried the coils, didnt fix it, yet I still got charged for them. Anyway, in the end for me it was a leak in the gaskets. Run a smoke test through your valves and see if there are any leaks. Soon as I sorted my gaskets out, the car was so smooth again :(
HKS quite possibly change their coilpacks as often as they do plugs.. which is after 7 seconds.. i have no doubt that the standard coilpacks are capable, when new.. but i think id rather cough up $600 for splitfires than $1500 for a new set of stockies.
where do you get that price from? i had no idea they were that expensive
the only place you can get them from... nissan. last I checked their 26 coils were about $300 each retail. why do you think people buy splitfires when their standard coils fail? it's not for the pretty blue colour that's for sure!
Last time i was at my tuners he said he had a pretty worked 34 gtr on the dyno. It was making ok power but not what everyone expected with the setup it had (I don't know details of setup). He said it wasn't missing/hesitating or anything but they decided to throw a set of split fires in as well as a set of HKS plugs. Straight away the car made 100kw more. He said the same thing as R31Nismoid, that the late model coil setup on 33's and 34's are just shit and he recommended his customers with late model skylines to change them, or keep this in mind, even before the car goes into the workshop. Anyway, my 2c.
well one thing I'd look at is plugs. as you run more power and more boost you need to think about the heatrange plug you are using. for a standard car 6s may be ok. personally even with light upgrades I'd go to 7s and with more boost and different turbos you may even need 8s. my silvia will miss heavily as it ramps onto boost with 7s, but runs amazingly well with a set of 8s in there. I know coppers are cheap and are "ok". i was a big fan of using cheap $3 NGK coppers and changing them a lot. but now having used true high performance Greddy and HKS plugs I can tell you there is a big difference. Since they use irridium tips they can run a very fine 0.6mm tip which is a good thing. high performance car should have high performance plugs.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
