  • Replies 41
  • 1 month later...
what are peoples thoughts between the 02 model and the 04 model EP3s? every one I see for sale here is 02 model but I really like the 04 model updates, the seats look better being black and red instead of all black (and I think they are a slightly newer model recaro) plus the front bumper air dam part is different and makes the car look heaps more modern and tough.
for the guys that have bought a few now, what are you paying in japan at auction for 02 models (clean 4.5, around 50kms) vs 04 models (again around 4.5a or b and around 40kms or so)?
would love to get a ball park of what I should be bidding on these as I'm about to buy one. I just haven't looked at enough post auction to see what the good ones are going for.
and a follow up question if I may, to all and sundry. who thinks it's worth the extra 300,000yen or so for an 04 model over an 02 model? judging by the stock in aus I would say most importers don't think it's worth it. I guess given the average customer wouldn't know there was an update for the 04 models then they probably wont pay any extra for them. but if you were buying one for yourself, not to sell, would you spend the extra for the 04? I do like the 04 front bar a lot more, and I like that the seats are newer styler recaro's with black and red trip as opposed to the all red trim in the 02 models. any other changes between the 2?
hmm, so even if it was for you to keep and drive you wouldn't splash out for the later model? my quick survey of local NSW importers agrees with you that for sales/profit wise you are best off with an 02 as bugger all people will know the difference here and even less are willing to pay $3700 more for a car that is basically the same thing with a few cosmetic differnces (and of course newer/less kms). buuutttt. I just can't help myself, I want the newer seats and I really do like the newer look front bar. I think maybe they have different lights too?
does anyone actually know all the updates on the 04 model? I'd love to get a list if anyone knows what they all are.
looks like I will keep an open mind as always and buy a good car, not a specific car. limiting yourself means less chance of getting a good car/bargain. so if a good 02 comes up at a good price I'll just have to live with it. :mrt:
thanks, always good to chat.
Courtesy of Wiki lol
2004 saw this successful CTR updated with many improvements - revised EPS with quicker steering, revised suspension settings, projector headlamps (JDM=HID, EDM=halogen), lighter clutch and flywheel assembly etc; based on Honda literature, this facelifted (FL) model was targeted at addressing customers' and critics' feedback such as understeer on the limit (due to the front Macpherson strut setup), numb steering response and lack of low end torque.
  • 4 weeks later...
hmm, thanks mate. damn, that pretty much cements my want for a 04/05 model then. :( I was just starting to talk myself into settling for an 02 and saving some bucks but it seems the 04 is worth the extra dough. and I'd say as they get older the gap between 02s and 04s will only widen.
  • 3 weeks later...
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
