For what it's worth I have Audi Q7 TDI, 176 kw/550nm towing GTR 34 / trailer all up 2100kg does it easy
Also have VW Touareg V10 TDI 230kw/750nm towing horse trailer all up 3200kg does it unstressed. Pardon the pun, horses for courses. Have driven new Jeep CRD, motor ok but not up to Audi/Porsche/VW TDI in terms of smoothness, low noise and economy.
For those of us where price matters..... The new Jeep is great value and fantastic build quality at $50K odd (compared to the older ones).
Agree, as a value proposition, very good, but unproven Italian VM Motori diesel scares me.
Good point.
The yanks have been using the new motor for months now so I'm expecting the Aus delivered ones to have any potential bugs ironed out by now. So far I haven't seen any significant issues.
I'm pretty sure VM Motori engines were also in the older Jeeps.
my dads other brother had a 3.5L v6 Pajero...was rubbish...could barely tow a 16ft fiberglass boat...mind this is going back a few years so I dont know anything about the new ones
Interesting. I had one and found it ok. I wonder if it was a healthy one. They tend to bmelt cats, blocking the exhaust and choking them.
03/04 WG Grand Cheks are ok. 5speed auto update, and the Limited/Overland has the good engine. Many are abused though, so it's easy to find a wart it seems.
Truth be known the Yanks can't even buy one. Us and Europe ate the first to get it. It looks the goods though, even better than the previous highly respected Mercedes unit. I have researched it and again, for the money..... :)
Compare it to a 550 Navara like I did last week. 70 bloody grand for something that doesn't come close build or feature wise.
I looked at the Navara and Toyota's and ran screaming from the dealerships for the same reasons you mentioned.
No, boats to over 4 tonne, though 2.5 to 3 is more within their scope. In a previous life I was a mobile marine mechanic. It towed daily.
Good to know. :)
I changed a distributor on a mercruiser 350chev in a 24ft cruiser...also changed the oil..........................never again!
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
