hey guys i just replaced my injectors in my rb20, they were the same size as the previous ones,
whilst doing this i cleaned the AAC
once all back together i started it up and it idles at 2000rpm, i followed the d.i.y http://www.skylinesaustralia.com/forums/Di...nd-t110431.html here and attempted to change the idle, going by the tutorial when i have removed the electrical connector on the AAC unit my car idles at 900rpm, so i assumed that the computer needs to be adjusted as indicated by the tutorial, when i turn the little screw on the comp it does nothing
any suggestions as to whats wrong?
one possibility that i thought is that although the injectors are the same capacity as previous they are in much better condition and may flow better, could this be the cause of the high idle?
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/
it may be possible but have u tried adjusting the screw on the aac valve itself...
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/#findComment-4622606
Resetting will put it to a default / factory setting (this is of courcse assuming you are running the factory ECU).
The adjustment on the ECU is a fine adjustment. The adjustment you need is on the base of the AAC valve.
Did you replace the gasket on the AAC valve - high idle is indicative of an air leak.
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/#findComment-4623696
i replaced all gaskets with gasket glue, the idle was fine befor i did the injector change and when i unplug the electrical connector on the aac valve it idles back on 900rpm which is what im after but once i plug it back in it goes back up to 2000
perhaps ill adjust the aac valve when the electrical connector is plugged in
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/#findComment-4624984
iv played with both the valve on the aac unit and the one on the ecu with no effect, iv checked for leaks and i cant find a thing, is it possible that it is due to the tune(when i had the car tuned the injectors had a leak and therfor more fuel was needed for start up and im assuming idle) could this cause the high idle iv got now considering these injectors are not leaking?
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/#findComment-4625730
Check your idle on startup, if it is the same as when warm then it is likely to be your IAC valve and it often causes problems. You'll need to pull of your main intake pipe and its best to remove the throttle body as well as it sits underneath this. It has a hose running to the bottom of it and one to the top.
The problem is the valve is pulled shut by a spring by default. This spring often deforms or snaps so the valve remains open when engine is warm and is constantly delivering too much air and raising your idles. You can open up the IAC and reseat the spring.
Edited by Kwyjibo
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/#findComment-4629025
id like to know how you go with it. my revs have been playing up too. cleaned the AAC but it came back 2 months later. Cleaned AFM and that fixed it for about 2 weeks. Car would idle normally on first startup and then play up after abit of driving. Could a possible leak from the vacuum hose that goes into the EBC be the cause?
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/#findComment-4632748
pulled it apart yesterday, the little spring was in perfect working order, turned out to be the little sensor thing that is attached to the throttle body, when you pull it apart it is conected to the throttle so i shifted it slightly which caused idle to drop to where i want it
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/#findComment-4641399
straying a little the valve underneath the throttle body (IAC) does it have anything to do with the A/C throttling up when it is turned on?
when i turn on my air condition it throttles down the car and sometimes coming to a stop it shuts off. i cleaned the one to the back of the plenum and i have seen no change. what could it be?
https://www.sau.com.au/forums/topic/272176-2000rpm-idle/#findComment-4663035
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
