Hi all,
First post from newbie to this forum...
Names Phil from Belfast in Northern Ireland i own a R33 GTR V-Spec
Been lurking around SAU for a while doing a few searches etc...
Has anyone used one of the Nitto Oil pumps on an RB26 ? If so what are your opinions on them ??
Cheers
Phil
https://www.sau.com.au/forums/topic/272195-nitto-oil-pump-rb26dett/
Half way between N1 and say a high end pump with a different design - Tomei
Being they are priced smack in the middle.
End of the day any pump can be destroyed, it all comes down to the treatment of it
Cheers man much appreciated...Do you think it is worth shelling out the extra for a Tomei/Jun pump this is a road car with the odd drag/track use....Revlimit set to 8k, harmonic damper, balanced crank etc...
Not really. I wouldn't if it was me.
I'd go with a N1, they haven't failed me in the two motor's i've had, nor anyone else i know.
But like i said, its all about the treatment. Dont flog the limiter and so on or you can even shatter a Tomei item
Thanks for the advice mate...
Personally I wouldn't use an N1, Jun or tomei.
Ive broken all 3 and have mnay many customers with broken Jun and N1 pumps.
Depends on your application for a roadie anything will be fine providing its balanced well.
The NITTO pumps you speak of are excellent. Ive tested them a few times in pretty high reving RB26's and never had one fail. Id rate them up there with the tomei/jun offering if not better from my experiance.
Id recommend you dont use one without some form of extended sump though.
On the engine dyno monitoring oil level we were able to empty a stock sump and fill the head even with restrictors and returns etc etc.
12 litres is about right from what we've found and those that sell them will also attest to it.
How can you put a Nitto above or even on the same level as a Tomei? Just because you are yet to break a Nitto or some other reason?
The Nitto still uses the stock gear setup which by design isnt the best.
The Tomei is a totally different design, the best of all the aftermarket options for RB's (without external).
But again, it all comes back to the treatment of them.
When circuit/rally/street/drag cars here in Vic can all run N1 pumps without creating mince meat of the gears because of sensible use, then that clearly shows those who are destroying stronger pumps are not being as forgiving/smart as the majority of people in this state.
Paul also in Twoogle ran a N1 without issue and all that did was 1/4 mile passes - again, comes back to the treatment of the pump and always will regardless of the brand
Did you englarge the Oil returns to 12mm or were they std size...
You gotta give it a year or two before anyone will have formed a factual opinion on these.
people can only speculate on them at the moment, but after a season or two they can see if its good/bad being punished for a period of time
At the end of the day its good that someone is still making parts for RBs (20 year old engine) but no one can tell you how they really perform
Mearly my oppinion based on my experiance Ash.
Im yet to see a Nitto pump fail and untill I do so for the money id keep recommending them above the tomei
There are loads of GTR's here that have no issues with oiling and I know of others that do. It all comes back to how they are treated.
He asked the question about the nitto pump and I gave him my honest opinion. When the nitto can be had for just over 1k its a bargain and up there with the best as far as im concerned.
The tomei pump despite being larger and a 3 peice gear set is still a gerotor type pump. Id not argue that they are probably the best however for the money I think they are overpriced and there is better options.
I use 12mm returns on everything even my dry sumped engines.
Edited by Risking
what were you on when you made this post?
.....But again, it all comes back to the treatment of them.......When circuit/rally/street/drag cars here in Vic can all run N1 pumps.....that clearly shows those who are destroying stronger pumps are not ...as ...smart as the majority of people in this state.
Are you really saying
a/ people outside vic kill oil pumps because they are dumb?
b/ engines are not failing in vic?
I thought those claims were mythbusted years ago. As soon as some of you guys had 12 months of track days on GTR motors they started failing and requiring rebuilds just like everyone else. And even now there are 0 GTRs in Vic doing any racing.
not true, in fact that oil pump failed killing the motor.
Anyway, bottom line is, any $2k+ oil pump is a total waste of money. If you are that worried and serious you should dry sump it for about $3-4k. If you are using wet sump the nitto pump is an excellent price/performance compromise.
One key feature Brad did not mention is they are serviceable unlike the standard pumps. If like me you rebuild motors regularly this runs to a very significant saving as the n1 oil pumps at 400+ each but should be chucked away after each motor.
due to the fact we had a oil pressure cut off, when the N1 oil pump failed the engine was fine...we could have simply replaced the oil pump and gone again.
I recommend Nitto pumps and id go along with Brads statement that they are as good as Tomei if not better.
Paul is your pressure switch hooked up to a relay that kills the fuel pump or ignition?
I've had one of the Nitto pumps installed in my rebuilt motor. Yet to run it up yet, but will soon have an idea on them myself. I also had a sump extension installed as well. I'm planning on taking my car to the track when it's ready. I'd read some good things about these pumps. I'm planning on taking my car to the track when it's ready.
To my knowledge the NITTO pump was derived from the GREDDY and JUN pumps.... im pretty sure it was a GREDDY one sent by CRD overeseas to be replicated, one of the reasons they were pulled from the distributors list. Same pump and cheaper cant be a bad thing really.
Copy NITTO pump
Original GREDDY / JUN (same pump)
Edited by URAS
Im saying exactly what the post said :)
That is what we are talking about - oil pumps.
The motors that are failing here, are not failing due to smashed/killed pumps.
Keep on topic :D
Your comment about 0 GTR's doing racing is wrong BTW... how could Snowy win Targa rookie if he wasnt using it? Or Jorgensen who was also in Rookie...
Or PLENTY of other people out there going in circles still in our championship and at various other days outside of it (not everyone is a member afterall) ;)
I just think its too soon to say Nitto's are any 'better' than anything else.
As you could draw the above as a viable conclusion based on people's comments in this thread. And im just pointing out i dont neccesarily agree.
Perhaps the people that have busted the other pumps and now using Nitto are taking it a little easier? due to them being reminded by a failure to be nice? ;)
(i can draw conclusions too) :)
BTW - I am in no way saying Nitto's are bad or below another product, just to its clearly stated.
OK guys. Let's set the record strait for all the TRENTs out there:
1: The NITTO RB series oil pump is not owned by CRD. CRD has been involved with the testing and development of NITTO's products for a number of years now including the NITTO RB series oil pump. The pump housing is based on a proven design and is obviously going to look similar to other pumps on the market as they are all designed to be installed on the RB engine. Where NITTO went a lot further than the basic mass produced pumps eg: N1, Greddy, Jun etc is that they spent 1000's of hours redesigning and developing the oil pump gears to cure the high rate of existing oil pump gear failure that is still evident with other brands.
Guys, you have to understand that "the wheel" so to speak has already been invented. What NITTO has done has further developed the RB pump with more up to date materials which are far superior in strength and durability.
2: As to the manufactures of the Jun and Greddy RB oil pumps, the extreme similarities in both pumps would strongly suggest they come out of the same mass producing factory????
3: As for getting kicked out of Greddy that would have to be the joke of the week as I personally have made it known in our industry that I pulled out at the time that Greddy Oceania was set up. All I will say without slandering anybody on a forum is which is the worst form of self disrespect anybody can do is to say that we had differences of opinions.
End of story.
Regards Jim Souvas
Tech Engineer
CRD
PS: Hi Trent! Havn't seen you since Tokyo Autosalon 2008. Give us call if you're ever up in Sydney. Cheers!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
