Hi all,
First post from newbie to this forum...
Names Phil from Belfast in Northern Ireland i own a R33 GTR V-Spec
Been lurking around SAU for a while doing a few searches etc...
Has anyone used one of the Nitto Oil pumps on an RB26 ? If so what are your opinions on them ??
Cheers
Phil
https://www.sau.com.au/forums/topic/272195-nitto-oil-pump-rb26dett/
Half way between N1 and say a high end pump with a different design - Tomei
Being they are priced smack in the middle.
End of the day any pump can be destroyed, it all comes down to the treatment of it
Cheers man much appreciated...Do you think it is worth shelling out the extra for a Tomei/Jun pump this is a road car with the odd drag/track use....Revlimit set to 8k, harmonic damper, balanced crank etc...
Not really. I wouldn't if it was me.
I'd go with a N1, they haven't failed me in the two motor's i've had, nor anyone else i know.
But like i said, its all about the treatment. Dont flog the limiter and so on or you can even shatter a Tomei item
Thanks for the advice mate...
Personally I wouldn't use an N1, Jun or tomei.
Ive broken all 3 and have mnay many customers with broken Jun and N1 pumps.
Depends on your application for a roadie anything will be fine providing its balanced well.
The NITTO pumps you speak of are excellent. Ive tested them a few times in pretty high reving RB26's and never had one fail. Id rate them up there with the tomei/jun offering if not better from my experiance.
Id recommend you dont use one without some form of extended sump though.
On the engine dyno monitoring oil level we were able to empty a stock sump and fill the head even with restrictors and returns etc etc.
12 litres is about right from what we've found and those that sell them will also attest to it.
How can you put a Nitto above or even on the same level as a Tomei? Just because you are yet to break a Nitto or some other reason?
The Nitto still uses the stock gear setup which by design isnt the best.
The Tomei is a totally different design, the best of all the aftermarket options for RB's (without external).
But again, it all comes back to the treatment of them.
When circuit/rally/street/drag cars here in Vic can all run N1 pumps without creating mince meat of the gears because of sensible use, then that clearly shows those who are destroying stronger pumps are not being as forgiving/smart as the majority of people in this state.
Paul also in Twoogle ran a N1 without issue and all that did was 1/4 mile passes - again, comes back to the treatment of the pump and always will regardless of the brand
Did you englarge the Oil returns to 12mm or were they std size...
You gotta give it a year or two before anyone will have formed a factual opinion on these.
people can only speculate on them at the moment, but after a season or two they can see if its good/bad being punished for a period of time
At the end of the day its good that someone is still making parts for RBs (20 year old engine) but no one can tell you how they really perform
Mearly my oppinion based on my experiance Ash.
Im yet to see a Nitto pump fail and untill I do so for the money id keep recommending them above the tomei
There are loads of GTR's here that have no issues with oiling and I know of others that do. It all comes back to how they are treated.
He asked the question about the nitto pump and I gave him my honest opinion. When the nitto can be had for just over 1k its a bargain and up there with the best as far as im concerned.
The tomei pump despite being larger and a 3 peice gear set is still a gerotor type pump. Id not argue that they are probably the best however for the money I think they are overpriced and there is better options.
I use 12mm returns on everything even my dry sumped engines.
Edited by Risking
what were you on when you made this post?
.....But again, it all comes back to the treatment of them.......When circuit/rally/street/drag cars here in Vic can all run N1 pumps.....that clearly shows those who are destroying stronger pumps are not ...as ...smart as the majority of people in this state.
Are you really saying
a/ people outside vic kill oil pumps because they are dumb?
b/ engines are not failing in vic?
I thought those claims were mythbusted years ago. As soon as some of you guys had 12 months of track days on GTR motors they started failing and requiring rebuilds just like everyone else. And even now there are 0 GTRs in Vic doing any racing.
not true, in fact that oil pump failed killing the motor.
Anyway, bottom line is, any $2k+ oil pump is a total waste of money. If you are that worried and serious you should dry sump it for about $3-4k. If you are using wet sump the nitto pump is an excellent price/performance compromise.
One key feature Brad did not mention is they are serviceable unlike the standard pumps. If like me you rebuild motors regularly this runs to a very significant saving as the n1 oil pumps at 400+ each but should be chucked away after each motor.
due to the fact we had a oil pressure cut off, when the N1 oil pump failed the engine was fine...we could have simply replaced the oil pump and gone again.
I recommend Nitto pumps and id go along with Brads statement that they are as good as Tomei if not better.
Paul is your pressure switch hooked up to a relay that kills the fuel pump or ignition?
I've had one of the Nitto pumps installed in my rebuilt motor. Yet to run it up yet, but will soon have an idea on them myself. I also had a sump extension installed as well. I'm planning on taking my car to the track when it's ready. I'd read some good things about these pumps. I'm planning on taking my car to the track when it's ready.
To my knowledge the NITTO pump was derived from the GREDDY and JUN pumps.... im pretty sure it was a GREDDY one sent by CRD overeseas to be replicated, one of the reasons they were pulled from the distributors list. Same pump and cheaper cant be a bad thing really.
Copy NITTO pump
Original GREDDY / JUN (same pump)
Edited by URAS
Im saying exactly what the post said :)
That is what we are talking about - oil pumps.
The motors that are failing here, are not failing due to smashed/killed pumps.
Keep on topic :D
Your comment about 0 GTR's doing racing is wrong BTW... how could Snowy win Targa rookie if he wasnt using it? Or Jorgensen who was also in Rookie...
Or PLENTY of other people out there going in circles still in our championship and at various other days outside of it (not everyone is a member afterall) ;)
I just think its too soon to say Nitto's are any 'better' than anything else.
As you could draw the above as a viable conclusion based on people's comments in this thread. And im just pointing out i dont neccesarily agree.
Perhaps the people that have busted the other pumps and now using Nitto are taking it a little easier? due to them being reminded by a failure to be nice? ;)
(i can draw conclusions too) :)
BTW - I am in no way saying Nitto's are bad or below another product, just to its clearly stated.
OK guys. Let's set the record strait for all the TRENTs out there:
1: The NITTO RB series oil pump is not owned by CRD. CRD has been involved with the testing and development of NITTO's products for a number of years now including the NITTO RB series oil pump. The pump housing is based on a proven design and is obviously going to look similar to other pumps on the market as they are all designed to be installed on the RB engine. Where NITTO went a lot further than the basic mass produced pumps eg: N1, Greddy, Jun etc is that they spent 1000's of hours redesigning and developing the oil pump gears to cure the high rate of existing oil pump gear failure that is still evident with other brands.
Guys, you have to understand that "the wheel" so to speak has already been invented. What NITTO has done has further developed the RB pump with more up to date materials which are far superior in strength and durability.
2: As to the manufactures of the Jun and Greddy RB oil pumps, the extreme similarities in both pumps would strongly suggest they come out of the same mass producing factory????
3: As for getting kicked out of Greddy that would have to be the joke of the week as I personally have made it known in our industry that I pulled out at the time that Greddy Oceania was set up. All I will say without slandering anybody on a forum is which is the worst form of self disrespect anybody can do is to say that we had differences of opinions.
End of story.
Regards Jim Souvas
Tech Engineer
CRD
PS: Hi Trent! Havn't seen you since Tokyo Autosalon 2008. Give us call if you're ever up in Sydney. Cheers!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
