Any of you guys had any issues with your wipers?
There seems to be a little slop in the mechanism that when running on intermediate the wipers stutter on return. Not sure if its just the cheap blades or if its wear in the motor assembly its giving me the shi#s.
https://www.sau.com.au/forums/topic/272328-m35-wipers/
No trouble at all, infact the smoothest operation i've ever had. I know what you mean, the wipers on my truck are doing that when there's not much water on window, really annoying! I'd splash out on some new blades.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4627402
Just put a new blade on, I replaced it the first day I got my car...
As I was going
BOSCH Areo Twin blade is the best I have ever used...
450mm and 530mm is what you need for a perfect fit for our car...
i bough them for around $ 25 each at supercheap auto!
cheers.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4629317
  • 1 month later...
know what you are saying exactly -- annoying stutter! mainly on intermittent ... dont think its the blades .... any luck finding out why?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4702467
I haven done any more research into my problem. I just dont use the intermitant. Its very weard as some times I think thyat it is the way it is controlled. Now and then I will get a quick 2 wipes in the int function.
I was going to pull them apart and see if I could reduce the slop.
By the time I get around to it I wont them anyway
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4702970
Mine had this problem when I bought it, I pulled the mechanism out and found the plastic ball cup was worn/broken. I replaced them with rose joints, then they worked smooth.
I have one spare plastic cup now.
The assy isnt hard to get out to check.
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4703303
The problem with me is that I dont have time to be messing around with it.
I will try to get onto it this weekend.
Whats a rose joint?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-4703355
  • 4 years later...
Thread dig, but very relevant.
I have a similar problem, and possibly the same cause.
When the wiper changes direction at the bottom of it's travel there is a clunk. Shifting the wiper myself lets me move it about 100mm at the tip. I expect there is a linkage or the above mentioned bush flogged out somewhere giving the joint play.
Any guides or information on removing the assembly from under the plastic cover?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7271791
Guys, this is a common problem for 2001-2003 stageas and skylines. you don't have so much dirt on the roads - so your wipers don't used to be as tired, as ours, and it is not common on your sterile roads)
you have to clean power distributor on the wiper's motor to remove gray dirt from the separating point oin the line, supporting the periodic duty!
just look for some pics
this is pic of my first Stagea. don't look at dirt - a wash engine room once in 3 month, but it has no affect...
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7273282
That's not the issue with his though, the white bushes on the arms flog out on some cars allowing the blades to flop around like a slapper's arse. ;)
Never seen those contacts being a problem on the 80 or so V35's/Stagea's I have worked on, can't be a very common issue... Perhaps it's the snow buildup on the blades in winter over there causing excess current draw?
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7273325
Scott, difficulties in translation) i missed with a problem)
the problem i wrote is only for 2001-2003 cars with mileage over 200 kkm - probably, you are right, hard work with snow matters
white bushes are too easy to find as a reason, for our severe circumstances)) - in Russia original spare arm with two bushes is around 10USD, replace and forget
https://www.sau.com.au/forums/topic/272328-m35-wipers/#findComment-7276267
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
