  • Replies 79
Bought one similar off ebay for my last car and it came from hong kong (touchscreen, GPS, TV, DVD) and it was great. played everything: divX, mp3s, WMA quicktime, played from dvd's, SD cards, USB thumbdrive. GPS worked fine, bluetooth for the phone was fine also. In a nutshell it was a great buy compared to $1000+ for a name brand unit. I could burn dozens of DivX movies onto a DVD and had hours of entertainment.
The instructions were a bit engrish and took a bit of work to figure out some of the bluetooth stuff but everything else was simple.
IMHO.
  • 1 month later...
So i cheaped out and bourght the cheap HK Ebay one... And i am surprisingly happy with it :yes:
once i re-arrenged the front speakers to come out of the rear channel and vice versa, it made the GPS SO MUCH better.
All in all its certainly no $2000+ 7" GPS Touchscreen Audio Player... but hey, it does the job nicely.
There's been a request to see it installed so this is it.
This is the one i purchased...
http://cgi.ebay.com.au/7-2-Din-Car-DVD-Pla...%3A1%7C294%3A50
It fits nicely, but the gear stick gets in the way when you eject disk in 1st, 3rd and 5th, but that woulde happpen with any Dub Din stereo i guess.
The sound quality is great too, i don't have it through running an amp, just through Focal 6.5" fronts, and it still sounds very clear at high volume
can you please take close up shots of its front and also tell us the brand/model# if known? There are quite a few of these yumcha units on ebay both from HK and local ranging from $200 to $500 and visually there doesnt appear to be any difference between them except price
CHECK OUT THE LINK ABOVE THE FIRST PICTURE!!!
check the link above the first picture.
it has GPS built in, and is surpisingly good.
Hi mate, do they have the latest OZ GPS map? Do they have USB function as well? And are the bluetooth, GPS sutff any good(reading maps fast enough so u wont miss ur distination) and easy to install?
Edited by Obelisk
Yes it has USB, it isnt so good because its at the front and has the "Generic Camera Plug" on the face of the sterio, they give you the adaptor cable with it...
I havn't even tried out the bluetooth...
and the map on it is well up to date, i havn't tried to update it yet. and it is MUCH quicker than my NAVMAN when it comes to directing you around the place, really quick on getting you back on track when ya miss the turn :P
the restriction to a max of 2GB SD card i would say is the biggest bummer with it, but then again, it was only $470 :P
I actually had one of these in my 33 for a while its a great unit the only thing i didnt like about mine was went u played mp3 cd's the backing colour was a greeny blue and was super bright at night and it lit up the whole cabin and thats the only thing i didnt like about it..... but the rest of it was great and only costs me $280 Inc postage of ebay
Anyone know if when this says iPhone ready, if the bluetooth will connect to iPhone and allow you to do dialling through the unit?
Really interested in getting one of these too given the feedback so far!
Pat, now that you've had it in for a while longer, is there anything else you found annoying about the unit?
Is there any info on how to update maps later on? Do you just have to download maps from "other sources"?
Also.. how does the TV reception fare?
Edited by UnCo
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
