  • Replies 383
ask and ye shall receive.
http://www.japaneseimportspares.com.au/par...riescoilovers/2
potenza 10/10 coilovers for 33/34 GTR, $950. get on it!
Never heard of potenza shocks, any good? Was looking at super streets or greddy somethings which are closer to $3k :D
hi guys, sorry for the lack of updates. i have been overseas on holidays recently and only now getting back on top of things/email.
as you all know the trackday course is three weeks away. you should have all paid the balance / full amount by now, so i will post up the list of paid drivers (as confirmed with John Bowe Driving) in the next few days. you've only got a couple of weeks to do servicing, check all fluids, tires and pads, so please get on to this asap. you don't want to be doing that sort of stuff the night or morning before the event! hopefully no one has any problems at this point.
ok, here is the list of people who are all paid up for the trackday (from John Bowe Driving):
1. moodles2
LukeENR34
TypeVU
Heslo
scandyflick
joshDC
Hostile
Nightcrawler
Krishy
32godzilla
Inline6
writeoff
ripp3r
14. bengi
you should all have received a confirmation email and invoice/receipt from Dean at John Bowe Driving by now.
i just need to hear back from Red Back (sorry, i don't know his real name) and Chalon as to whether they have paid the balance and received their receipt from Dean at John Bowe Driving. if anyone knows how to get hold of them quickly to confirm, please let me know!
cheers
I dropped off my car at Manta on Monday with a LONG list of things to get fixed before this event. I dread the bill I am going to receive but I need my 4WD, ABS, PFC, intercooler, brake ducts and engine working properly plus a stack of other things. The rest can wait until after the big day. Hopefully the GTR will be ready and I won't have to take the Pug.
all sorted. chalon has emailed me and will sort out his stuff today.
Krishy - i have asked Dean to re-email you the receipt.
looking good guys - i will send out / post some pre trackday tips and meeting point suggestions next week to help with finalisation of your preparations.
cheers - Kim
i would like to go but my car is still getting work done to it so no go for me. :D
really good opportunity to gain better driving skills and to learn how your car will react.
anyway have fun guy's it will be a blast.
Cheers mate
Yeah i cannot wait and see what the car is like on the track....also hoping that someone can get some good shots
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
