You obviously have never been in a properly set up Supra for circuit racing.
I was being rather sarcastic.....have seen some mad supras on tracks
Hey Krishy, I will take some shots for ya while your in action!!
Thanks for that martin.....looking forward to it woot woot
  • Replies 383
Hey George, are you taking your Supra to this? Have you finished all the mods (turbo, manifolds etc) on your car now?
Looks like my car will be stuck in RWD with no ABS so I'll be the guy facing the wrong way each corner and having everyone take evasive action around me.
The new G sensor which my car needs costs about $3000. F**ken GTRs! :thumbsup:
jeez man buy one from a wrecker... screw a new one
-D
Gtr's run as a RWD anyway unless ur under full load. The GTR behaves like a rear wheel drive car and is very tail happy as we found out with mine and a certain V8 500 driver last week at Mallala. So you have to be correcting yourself the Attessa can only do so much and we were drifting and correcting nearly every corner and you can feel the correction with the application of front wheel drive but it still has no effect when your pushing the car beyojnd its limits and you still have to rely on your own driver skill to negotiate the turns.
yeah but he's got a fwd daily :P no chance lolz
i have no abs either, shell be right steady foot works best :P
^^ and its not quite full load or 100% rwd, watch the dial when you put ur foot down, itll go to about 10% fw torque. theres usually something going to the front but in the end 32s still feel pretty much like a rwd on most bends
Edited by Inline 6
Picked up the car from Manta yesterday and despite the G sensor indicate red and failing the diagnostic test it now has 4WD & ABS :huh:
Funnily enough when we put it on the dyno today at HiTech it didn't want to come out of 4WD despite the fuse being pulled and the Field torque split controller being unplugged. The new BlitZ EBC and oil lines to the GReddy catch can will hopefully be sorted on Thursday and I think I'll fit the Recaro race seat for the day. Fingers crossed all goes well.
Now I'm just debating whether to buy a helmet before the 25th? I know it's not mandatory but with my driving history and luck...
as the course is set up as an introduction to track days, we won't be going flat out 100% to maintain safety and also to minimise the cost to the drivers (recognising that not everyone wants to invest in a helmet if they haven't decided on whether they're going to do regular trackdays yet) but it's up to you if you want to bring one along on the day.
so I'm not familiar with how much the wear and tear will be on my car so heres what ive done.
-new tread all round
-new coolant
-mobile 2000 10W-40 oil and filter change
Do i need to have new brakes? if so whats good brakes? no green or red stuff ideas tho(too expensive) just chuck me good brand an what id have to pay for 2 pairs. i got some dot4 factory line racing brake fluid for when i put new pads in.
anything else i may need?
I'd keep your tyre pressure's at at least 30 psi, if its a cold day or raining you wont get enought heat in your tyres and you'll just slide around or roll the tyres of the rims. Take a tyre pressure guage with you and when you start to push the car hard for a few laps then check the pressure, try to keep it about 30-36psi. I doubt you guys will see much of a pressure increase as this couse is only a beginer thing and you wont have helmets so i doubt you'll be able to push your cars very hard.
actually, the instructors recommend that you start with 42-45psi with street tires to stiffen the side walls for cornering - this is Item 1 of your pre-trackday checklist that is part of the course receipt that Dean from John Bowe Driving has emailed ALL of you going.
this also prevents the tire rolling on the rim with hard cornering, but i suspect that many of you have stretched profile tires anyway :)
i would start with minimum 38psi cold (17"-18" street tires) before you leave home as it will probably rise to 40+ by the time you reach Mallala. it is better to have over inflated tires rather than under inflated as you can always let excess pressure out there (unless you have a portable compressor or pump with you). and dstroy is right - your tire temps won't increase a lot if it is a cold/wet day.
for semi slicks, you would start with 28-30psi cold as these can increase to 34-36psi when hot (after hard cornering, acceleration and braking). you would adjust the pressure for these tires in between laps based on the tire wear across the tread face (need edge to edge wear).
Edited by V35-2005
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
