Hey Guys,
First thing is first, yes I am in the Exhaust industry, and Secondly I am not here to cut anyones Grass with the Group Buy thats going on at the moment.
What is the general feel on Dumps, Split or single on the M35's?
E man
I have not been able to read a lot about the preferred choice on dump pipes for the m35 as there are not available. The only ones I have seen ex japan are single bell mouth.
I know Liverpool exhaust have done a split dump for the M35 and the guys who have this are happy with the results.
Beyond that I can not really add much to the discussion if this has added to it at all. :P
I would personally be happy with any improvement at a reasonable cost.
Cheers
Andy
Coming from an R33 GTS-T, I have always been led to believe that split is better than bellmouth.. But on the RB25s you get a combined dump and front pipe replacement, that seperates the wastegate and turbine gases all the way to the single cat. Aparentlty the power benifits are huge...
With the M35s having a much shorter run from the turbo into the next cat, are the split benefits more margional, like those little dump replacement pipes for the RB26s?
i take it i met you today @ liverpool
what size pipes are you running for the spilt?
I am he, as for the split sizes I am un-sure.
As I said at the start of the conversation I am not hear to cut anyones grass, just to provide advice and receive feed back.
Here is the punch line, I did mention to you about the dump being available on the market soon, well it's available now.
E-man
dont see the need for a split with the m35's exhaust housing, its not going to do what splitting the housings/gasses is good for, wouldnt a bigger bell mouth exhaust flow more?
p.s. tell em the price son!
Firstly 3" will flow 3", and whether it is split or single 3" if will still flow 3".
The reason for the split is to stop the turbulence caused when the wastegate opens, we can all establish that.
The next thing is to make sure you have a long enough split. If the separated pipe is introduced to early you end up with turbulence again (eg the jap branded version 1 split dumps on sr20's RB25's and even RB26's).
What we have found is that you have to introduce the waste gases after a certain point to start an extraction effect, same way we design Headers(Extractors).
Back to the bigger bell mouth.
Yes Bigger is better than some split designs, to give an example.
In the XR6 Turbo's, people pull off the split 3" designs and go for a single 4" design, gaining more torque and top end power, but the difference here is that the XR6 has heaps of room for a big dump, where the M35 does not.
With this info at hand We tried for a 1 piece design, but required donut bends to be used as the first bend of the dump pipe, hence providing more work for no more power.
You will notice that in the photo of the single dump of the single design thats floating around on the forum that the first bend is a different shade to the second bend, this shows me that the first bend has been casted and welded to the flange and the second bend (a standard mandrel bend) has been welded on to the casted piece.(outlined in my illustration)
Now the M35 has very little room, so the split design is the most efficient for power, torque, and clearances to the body.
Back to the question "wouldn't a bigger bell mouth exhaust flow more?"
the answer is yes, but a 3" single flows the same as a 3" split but the 3" split extracts the gasses out better and more efficiently giving you better torque and power.
Angus, now since you asked I will work out a group price for forum members but would require a show of hands (PM Preferred).
But as I said I am not here to be the Jim's Mowing Man and cut your turf or your dump pipe, but offer M35 Enthusiasts a good quality product.
PS. we also do Ceramic Coating, and yes it is the Made in USA stuff
E-Man
just so you know, that top piece is CAST, there is no such word as CASTED.
and im happy to purchase from either person, maybe whoevers is first, looks the best quality (probably THE most important part), the material and price...........
What do you think if you have a high flow turbo? Would it not be better to still have a single? I had an R32(about 650hp with high flows) years ago and we started with splits and switched back to singles...worked out better for us....is that because we had more room to do it properly.
Also what do you think if you had no Cat(for off street use only)....would a single or split work better?
Edited by Jetwreck
that first piece isnt cast. your kidding right??
and your main exhaust pipe from your split isnt 3 inch. it would be closer to two.
the first bend is a tight 90, not that hard to achieve. it is in no way cast!
its stainless just like Tomei's version below.. these are on my gtr, and without a doubt flow alot more than a split design system like Trust's long split front/dump
no Cat for "off street use only"? Take that tongue out of your cheek young man!
hmm, I don't think that this will be a "one size fits all" type of item.
You and I both have highflowed turbo's, but your is much shorter than mine.
You also have a custom dump back I believe, where as I have a Kakimoto front pipe and a Fuji exhaust... probably a different total length (I couldn't fit that flexy bit between the dump and the front pipe from the OE system)
I have seen a couple of other M35 exhausts and they are both different lengths as well (muffler tip to front pipe flange).
How much longer than the OE dump will these units be?
Will they need a specific front pipe/cat?
Could/would a bellmouth design be shorter than a "correctly extracting" split design?
Edited by iamhe77
it is an interesting area. we made more power everywhere with a bellmouth over a very high quality name brand long split dump.
there wasn't heaps in it but back to back more power/torque with a bellmouth up around 250rwkw.
having a larger negative pressure area just outside the turbine outlet provided by a bellmouth may allowing room for thermal expansion that a split doesn't allow?
I'd like to note, the flange for the stagea fully open will just fit a 3 inch round pipe belted into shape..
his is a split system.. now that means you've just lost over 50% of the flanges size dew to the split design..
there is no way his exhaust is 3 inch all the way.. its impossible to do this with a split design..
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
