hey all. i need to change the brake pads and rotors on the 260 (s1)... r they the same as the 33 gtr being brembos?
im looking to get slotted... dno y is there any reason to or not to?
and pads... i realllly cbf cleaning my wheels any longer what doesnt give rude amounts of dust! :banana:
cheers
adam, your brembos are the same as those on bcnr33 (r33gtr) and bnr34 (r34gtr) only difference is in the caliper mounting bolts
if you want, you can buy my rotors, and i'll pay the extra to get myself some slotted, if you don't want to fork out too much at the moment
I went for the Project Mu b spec pads, awesome bite and work straight away, a little dusty but not as bad as the formula ferodo's ive had before.
I just went some stock R33 GTR rotor's, at the time i wanted slotted but didnt have the kesh.
I run RDA slotted rotors and QFM pads in the skyline. I've used them at the track a few time and both have held up awesome, not much brake dust at all with the QFM pads and they are pretty cheap as well :bunny:
Racebrakes RB74 pads, or Endless SSS if you want to spend more for less feel.
RDA slotted rotors.
hopefully would be 200 per end for rotors and 170 per end for pads!
per end? i think you mean per corner.
just some info i found from a sponsor on ns.com
GTR BREMBO Pads (R33,R34 some WRX and evos, PM if unsure)
EBC-31032 Front set Redstuff $300
EBC-31538 Rear set Redstuff $168
Redstuff
Temp range 0-775 degrees celcius
bite cold 0.46
min friction @ 120mph-0mph 0.25
BREMBO Discs
324mm RDA-7701 Front RDA Disc ea $160 Ask for stock +$20-40 postage ask for quote <---- that's for non slotted
324mm RDA-7701s Front RDA Slotted Disc pr $Ask+$20-40 postage ask for quote
where should i get them... i got a quote for 33 gtr rotors from ABS today.. like 320 for fronts each, 230 for rears... i think pads were like 180ish? but seriously..... chances of not bending me over:( lol
Adam, GSL Rallysport are selling QFM pads through the Classifieds Business Traders' section here on SAU... They can also hook you up with rotors.
Might be worth looking into, plenty of people report that they perform well and are low in dust.
If you have rotors which are in good cond you can get them slotted. They are usually machined in a straight line but if you think about it for a second or two you can see that they will work as well as the visually more exciting curved slots.
Agreed.
I have the QFM A1RM pads on my car (daily driver). Pulls up much better. No dust (which I needed) and no noise (which I preferred).
Seem to have a pretty good lifespan and are a GREAT price too!
Definitely recommended. :P
go for DBA slotted rotors
and search ebay for good brembo pads
I found a set of Panoz (Wilwood)4-pot billet aluminium calipers for $150del. + Wilwood Superlite pads for $100
cant wait to modify and install !
ebay: some cheapy pads http://cgi.ebay.com.au/GTR-200SX-300ZX-IMP...p3286.m20.l1116
and http://cgi.ebay.com.au/Nissan-Skyline-Fron...p3286.m20.l1116
FYI EBC Redstuff pads squeak like buggery, I have these with slotted rotors and my car squeaks everywhere. They are great once they are hot and they stop you bloody quick when you mash the pedal to the floor but I don't reckon they are that good for street driving. I would go for a less aggressive compund of you are looking at ebc pads either go green stuff or maybe some project mu pads they are pretty good, racebrakes stock them.
i got a set of rda? slotted rotors for $310
and red stuff ebc for $250
i took in the group buy page n was like what ya gna do bout ur $200 over prices situation n she matched it instantly :down:
i took in the group buy page n was like what ya gna do bout ur $200 over prices situation n she matched it instantly :P
i owe ya one for the hookup too :)
much love
its adam on chris account lol
u sureee do...,when should i grab $ off ya? coz ill b stuggling to pay for em b4 i get $... :) i love week to week :P
got cash whenever you want it, just gotta get it out from an atm or whatever :banana:
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
