  • Replies 81
Troy, I think the plan is to have a couple different stages of modification. The will be bolt-on internal gated turbos to fit stock manifold as the base stage, all the way up to custom manifold, extrenal gated turbo with full management.
Hi guys, in case you missed it in other threads, they are unning 50 psi fuel pressure at idle with a rising rate fuel pressure regulator. So to achieve this sort of result, the injectors are exceeding their rated output by around 40%.
My previous experiences with "overdriving" injectors more than 10% has not been very good. The solenoids and springs simply don't like it. Take the risk if you wish.
Secondly the car is not driven everyday at 431.6 rhhp. I believe GTS-t Vspec quoted 360 rwhp which is under the widely accepted 450 bhp maximum for daily use on a standard internals RB25.
Hope that clarifies
I have been driving it with the 431rwhp over the past couple days, and I must say it's a heap of fun, but in order to save my stock internals I feel that the 360rwhp is a much safer level for the engine until I get forged pistons etc.
If I do have any trouble with running the stock injectors at high pressure then I'll let you all know, but so far they've performed admirably:D
nice numbers paul
I got a 0.70 a/r front with t66 comp wheel and 0.82 a/r rear rated at 600hp turbo going on my car at the end of this week, i got the same manifold as you but 550cc injectors and a power fc with 044 bosch pump. Should i expect the same numbers as u? As i was told it would need atleast 20psi to get 300rwkw..
Interesting. I've run out on injectors on my car now @ 203rwkw (what is that in HP?)
Admittadly im not running a rising rate reg, but i surely wont be getting another 100rwkw out of just raising the pressure.
Also im running a Factory ECU with a chip that really hasnt had it's map changed at all.
Just speed limiter removed at this stage.
Now, i dont think my car is making anywhere near 400rwhp (im not sure of the conversion)
And my car to date has come home with 12.98 @ 108mph.
Paul... did you run the mid 13 @ 411rwhp?
If so... that's awefully low MPH for that kind of power... (if 400rwhp is more than 200rwkw)
As if you get wheelspin or not, your MPH is usually more or less the same. Just your ET that changes.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
