easily overloaded tho
say u wire in power from the ciggie lighter
then plug a GPS into the ciggie lighter can cause it to overload and blow the fuse.
They're on two different circuits. The lighter power and light power sources are different.
I had a guy come to me wanting me to wire in 8 gauges (yes 8) in his car. What I had to do was use relays to power both sides and use the spare in his fuse box for overload.
If you're only running the one gauge you'll be okay to pick it up from the lighter light circuit, even better if you used LED's to keep the current draw down.
+1 for cigerette lighter. the light uses a serperate power feed but the same earth as the power for the lighter itself.
mines been running off there faultlessly for near a year. Using an LED in my boost gauge but :bunny:
Link it off the ring around the cig lighter. That turns on with headlights
Its the top connector in the picture below;
Instructions on how to get to it is here;
http://www.skylinesaustralia.com/forums/R3...em-t204874.html
I'm also trying to find wire clips (that let you tap into power from an existing wire), but can't for the life of me find them on the Jaycar website, are they called something else?
Scotch lock quick splice connectors. You can also use T-taps.
Should have mentioned. Go to any car parts mob like Malz, or Stupid Cheap. You'll have a better chance of finding them there than at Jaycar who are more electronics oriented.
Dick Smith have some that wrap around the source wire, and provide a spade connection for the branching wire.
o cheers for the info
my friend must of linked it to the wires going to the actual ciggie lighter .. not the circle light around it.
so if i link a boost gauge to that wire it will dim it self at night?
If you use the cigarette light, it will be full brightness at night, and not light at all during the day. Though if you lightsource the climate control uses, it will be full brightness during the day and dim at night (that's if the light will work on the dim voltage whatever it be)
so if thats the case i would connect the purple dimmer wire on the guage to the climate control and the red power wire to the ign wire or something similar?
Now that I think about it, putting the dimmer wire on the climate control is a bad idea, since you would need the climate control always turned on.. I didn't think about that consequence since my CC is always on. Stock headunits have a dimmer function iirc, if you have a aftermarket headunit just look for a wire not connected (im guessing nobody keeps the dimming function with A/M decks)
you dont need the light to be on during the day?
just go straight to the cig lighter light. Easiest and most effective. Dont worry about diming and stufff. If your that worried put a variable resistor in the circuit somewhere....
