Regrettably, the time has come to sell my pride and joy in order to move on to bigger and better things in life. I'm the first and only owner of the car, since having it personally imported for me, through J-Spec. It was purchased in 100% stock condition right down to the factory exhaust and wheels. Every modification and all of the work done has been done here by RE customs.
The car has been serviced every 3 months/5000km's whichever came first, by RE customs, using top of the line Motul oils in the engine, gearbox and diff.
There is currently 123,000kms on the clock, with 28,000km's on the turbo and engine since the rebuild.
1998 Series 2, 40th anniversary edition
Engine
-Rebuilt RB25DET
-Arias forged pistons
-ACL race bearings (big end and main)
-Reconditioned head
-Gates Racing timing belt
-HKS GT-RS (purchased brand new from Nengun at the time of the rebuild)
-S15 440cc injectors (only been in a few thousand kms)
-Z32 AFM
-Splitfire coilpacks
-Bosh 023 fuel pump
-SARD fuel pressure reg.
-3" turbo back exhaust consisting of Xforce stainless steel bellmouth front/dump, Catco highflow cat and Xforce mild steel catback
Last dyno run made 253rwkw on 18psi
Cooling
-Blitz LM turn flow front mount (no holes in chassis, stock piping retained)
-Trust 13 row oil cooler kit
Suspension and handling
-Sydney Kid GB Bilstein shocks with Whiteline springs
-Front and rear Whiteline fixed sway bars
-Front and rear Whiteline camber and castor kits
-Whiteline rear subframe alignment kit (pineapples)
-HICAS lock bar
All suspension fitted by Centreline suspension in Thomastown
-Cusco front strut brace, Nissan rear strut brace
-Volk 18x8.5 18x9.5 +22 bronze TE37's in perfect condition
-Hankook K107's, 235 front 265 rear
-Rays Duraluminum lightweight locknut set
Braking
-RDA grooved and dimpled rotors front and rear
-QFM A1RM pads front and rear
-Rebuilt calipers front and rear
-ADR approved braided brake lines
-Brake cylinder stopper
Electronics
-Power FC with hand controller
-Blitz SBC Spec-R EBC
Interior
-Rare factory option MOMO steering wheel
-Autometer Cobalt series gauges (boost/oil pressure mounted on pillar, oil temp mounted in DIN slot)
-Genuine series 2 floor mats (not the ugly white speckled ones seen in most 33's)
-1kg CAMS approved fire extinguisher
-Pioneer DEH-8650 MP3 headunit
-Alpine DDD 6" splits front, 6" rears
-Amec black 300km/h cluster
-Blue L.E.D cluster lighting
-Nismo leather gear knob
-Apex-i turbo timer
-RAZO pedals
-Insurance approved black wire alarm system/immobiliser etc
Exterior
-Type-M body kit with factory fitted genuine adjustable GTR wing
-Tinted windows
-Nismo smoked side indicators
The plenum and all visible piping, as well as the intercooler, brake callipers and hubs have all been powder coated black.
I have receipts for pretty much all parts and work carried out as well. All parts have been purchased brand new and quality Jap brand name parts have been used in lieu of cheap Chinese imitations.
Price: $21,000 ono
I'm willing to sell without the TE's (stock rims will be provided) for a lowered price.
https://www.sau.com.au/forums/topic/274145-1998-series-2-r33-gts-t/
I endorse this product and or service.
Was in mint condition when we imported it for Dezz, was the last of the R33 GTSt's and had all the factory goodies that Nissan could throw in it being a special edition. all mods done in oz from scratch, and its still mint.
GL with sale.
This is the best R33 gtst for sale i have ever seen, has everything i'd want for it and been rebuilt.
Thanks for the comments, usually comments like that only come from the sellers mates but pretty sure I don't know you lol
Listen to what he has said.
If the buyer doesn't want the rims, then he will sell them.
Yeah pretty simple really..
Also forgot to mention, rocker covers and timing cover have been professionally painted in Cusco blue.
Apex-i panel filter always used in the stock airbox
In a few of the pics it looks like theres gtr or aftermarket seats in it, something else you forgot to mention? lol
Edited by Joe_89
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
