baaaaaaaaahahahahaha, i laugh so much because i know how you feel had that happen when getting my licences. i thought i was going to suck at the AMG challenge but i actually did quite well. generally silver first attempt (didn't bother trying again). the very first one i did i was just planning on passing it and not caring what i got. do the first run, get to the fast left hander over the crest before the right hand hairpin and finish line (the first section of the track) and i had a massive off, into the wall, across the road into the sand. get back on the road, about 50m from the finish, look at the time, has just ticked over the time for silver. so i had to do that one again knowing that i could easily get silver.
B-spec Lev.25 baby! :banana:
Easy street now- Much less button pressing required
Time to set Bob on getting me my X1 f**ken
easy street you say? i dont think so.. why would there be any less button pressing? and dont tell me your going to be a douche and put a le mans car or something into an endurance race full of stock jap street cars, wheres the fun in that?
the first endurance race only gets ur xp about halfway thru level 25 meaning you either do it again, or re-do the other races over and over and over..
There's not really to much fun in b-spec anyway. The drivers I have suck
I get so frustrated when my driver won't get up the inside into a corner, or struggle to overtake on the straights. I think the b-spec mode was way better in gt4 where you could just set the speed you wanted them to go but I guess there trying to make it a bit more technical in gt5
I tried B-spec the other day... first race and I put the prick in my mod'd R31... big mistake.
every fkn corner exiting crazy power oversteer but i'll give him a little credit... he didn't ever actually lose it, just came dead last :)
lol yeah, i've said it before and i'll say it again, the low-level b spec drivers are mentally retarded.
when we a-spec, we usually late brake into corners taking the inside and forcing the opponent out wide. the b-spec drivers do start making more heroic moves like this and pull way better times at higher levels, my best driver is level 24 atm and he's pretty awesome, although i can still get better times myself.
Edited by jonboy
that's EXACTLY what I'm gunna do mahfugga. or should I say -am- doing; Bob and my Minolta should be just about finished taking the big stick to the competition for the 3rd time on the Grand Valley enduro
and you'll no doubt be pleased to hear I plan on using the most over-qualified car possible for every endurance race between now and nabbing that X1 :D
that's how I roll. oh yeah
my B-spec drivers are still retarded. they are only at around level 8. i had one in my lp560, in the french only race on the madrid track i think (one of the city tracks). by the first corner he was up to 3rd by the first corner. had some alfa and a (i think) lancia or something like that in front of him. was still in 3rd after the second lap. as you said, no taking the inside line, etc. on the straights half the time he was just ramming the rear of the car in front rather than pulling out to go round them. then if he did pull out he would only just have the nose of the car up to about the rear wheel then even though he would be on the inside line for the corner he'd brake early, then floor it quickly then brake again. then he ended up spinning out. he managed to get into the lead eventually, but the front bumper was barely still attached.
for the sports truck one at daytona i had an ford SVT and i had to fully modify it for the moron to be able to win. he was just too slow on the corners that was was last by the end of the first corner even with it semi modified.
can't remember if it has been posted in here or not (and too lazy to go looking), but this video shows how dumb the B spec drivers are. the b-spec driver has spun out and can't get going again
http://www.youtube.com/watch?v=CKNk8jN9vfs
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
