Hey guys,
I have some quick questions, my car is stock standard only has Catback exhaust and after market apexi airfilter pods. Everytime i get in the car ,it smells like fuel... is that normal for r32 gtr? or is there something wrong with it?
Secondly, Full tank of petrol can only go for 320kms, Is that normal? Maybe i need to retune it or something? because of the airfilter?
Thirdly, I just bought Xd9 18"rims last week. it was very close to the guard so i needed to get it rolled. Got the guards rolled 2 days ago, the paint cracked on one side as warned by the roller. He said that the left rear guard had been fixed or soemthing before and it has completely no metal at all. Anyway i want to know whats the best way to fix this?
Please help me out guys
Cheers
long
https://www.sau.com.au/forums/topic/275194-1993-32gtr/
Mine smells of fuel sometimes, they just do for some reason. Have a look for any fuel leaks.
Welcome to the world of high performance (read: high fuel consumption) cars. I get 400 to 450 out of a tank if I drive it economically. Are you still running standard boost?(about 7psi/0.5bar i think)
It's pretty common for the rear wheel arches to rust out due to the salt on Japanese roads and sounds like your was just patched with bog. Mine were cut out and new metal welded in. You'll have to take it to a panel beater to get it fixed properly.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4662820
Im running my car with standard boost 7psi and theres still only 350kms for a full tank, so im assuming its might be out of tune?
Yea, the guard roller said if i fix it they just gonna put more bog on??
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4662882
You smell fuel, probably because you don't have a catalytic convertor, or yours have been hollowed out.
350kms is a bit low, but not stupidly so... Car might be running rich. Standard ECU?
Take the car to a panel beater... They'll have to bog up the guard again, and repaint it... Of if you want to do it properly, pay them to weld in some more metal, hammer it back into shape and then repaint.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663043
Hey guys,
Cheers
long
I havent come across any skyline, turbo or not that doesnt smell like fuel while idleing.....
Another thing that might cause the high fuel consumption is if the O2 sensor(s) are not working, so the car runs rich all the time.
+1, i recon its more likely than not your 02 sensors, everyone forgets to change them but nissan recomends changing them every 40 000km or so.... mines not a gtr but when i first got the car i was getting 250ishkm/tank.... change the ot sensor, new spark plugs, throtle body clean, afm clean and now up to 500km/tank while running 10psi boost and about 200rwkw, if i drive it harder i still get 400km/tank at worst....
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663181
Hey guys,
ive owned a couple and only 1 ever smelt of raw fuel , it actually turned out to be the injectors that were leaking :D
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663364
So you're talking inside the car right? Check the seal on the fuel tank. In the boot there's a metal plate held on by four screws to the right of the wheel well. Under it there's a big black ring that holds the fuel pump and gauge assembly. There's a seal that sits between the assembly and the ring. Make sure that seal is in good condition and the ring is tight.
Other than that i've used gaffa tape around the metal plate to stop any fumes from entering the boot. The boot doesnt have an airtight barrier into the cabin, so any smell in the boot gets straight into the cabin.
FWIW i dont think my car smells bad outside. Cat and o2 sensors are known good.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663826
So the stock gtr doesnt have catalytic convertor? I am running standard ECU nothing has changed.
Yes i want to get it done properly no point of having more bog :D. So much money spending on the car but i mean my car is in good condition interior is perfect, engine bay is very clean, just stupid rust underneath the rear.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663897
do you think i could get it check up at the mechanics? or do i need to find a skyline specialist to fix this problem?
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663911
this is what i would be checking.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4663952
you would want to check that the fuel tank doesn't have any perished breather hoses and also that the fuel injectors aren't leaking, rather common for these early jecs/bosch fuel injectors to leak from the body and they must be replaced they can not be repaired.
whether it's a gtr, vl commodore, nissan exa, very common now they are getting on in age...
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4664837
Hey guys,
Cheers
long
Hey LoNgStAr!
First time poster for me in the NSW thread as I'm from VIC.
As some has already said on here,
Check your fuel injectors to see if they are leaking or not... If they are not leaking, run a can of injector cleaner next time you fill up your fuel tank.
Check you O2 Sensors out with your mechanic.
Check for any leaks in the fuel tank area. Fill up a full tank, take it for a drive, come home and park it over night as next morning see if there is any fuel stains around the rear area... Get mechanic to check it out... Look under the car for any leaks too.
350kms, that sounds low but not bad... I get about 250kms from half a tank and about 450kms - 500kms full tank.
See how you go.
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4666161
Hey long,
It's basically gonna be one of what's been said so far. Either injectors, fuel lines, 02 sensors or a leak somewhere around the fuel pump cover itself. Yes a computer will help with fuel consumption but that's an extreme measure just to try and fix the consumption part.
On another note, got any pictures of how the xd9's look on the car? Love these wheels on gtrs... =)
https://www.sau.com.au/forums/topic/275194-1993-32gtr/#findComment-4668503
  • 3 weeks later...
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
