  • Replies 57
nothing about that car is good, terrible styling, and even worse modification, i think the only part on that car even remotely good quality is the pod filter.
every expense spared.
well whats new.....typical Aussie style (hot 4's) styling..................
Custom cars dont look like this in Japan
there are shit cars in japan, it's just the amount of good ones makes up for it lol
it's the difference in culture, cars like this one revolve around this gay culture of buying a car and modifying it as an extension of ur penis, rather than actually trying to create a style you like.
there are shit cars anywhere in the world....
the cars were designed in japan, and the market there is huge with options on aftermarket goods.
over here, pretty much every customised car in the autosalon or hot 4s disgust me...
in saying that, real bogan rednecks WANK over thier stupid new Fords and HSVS... but theres not even that big a big market in aftermarket goods for thier beloved and most worshiped cars..........
OMFG!
G STYL uleh!
The APexi Pod is worth more then this entire ass raped car.
OH MAH GAWD BROW!!!!!!!!!!!!!!!!!!!!!!!! Laik, Youz dun laik mah Custom painjob broz?!?!?!?!?!??!!?
omg thats failsauce, srsly, who in their right mind says "hmmm i like this green, im going to ruin this nice car with it, then im going to vomit on it because you wont notice the vomit." lights are fail, stock lights or at most the led normal lights are the only good ones :P also, just me but the kit fails to, dosnt look right with the wheels
LOL!
Nah uleh, it's like full shit.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
