Hi everyone,
My parents had recently bought a stagea m35 ar-x. I was originally after an Apexi pod filter but i was unable to find one for that particular model. Would anyone know if they are they same fittings as the older model stageas or r34? Or any highly rated pod filter that anyone would recommend.
any help would be appreciated.
cheers!
https://www.sau.com.au/forums/topic/277080-which-pod-goes-into-a-m35/
i believe they are different to C34 intakes.
the V35 kits apparently dont fit either, but considering they use the same airbox setup, i dont see how they would. but its a risk.
there ARE M35 kits, but if youre buying from japan, be aware you MUST have one for an NM35 VQ25DET. or just put a panel in the stock airbox like most of us have anyway
Hi everyone,
cheers!
Yes, the Blitz LM and SUS Power pods both come in a kit for the NM35.
Don't think that they offer the greatest filtration though.
Try to find a place that stocks 3A Racing pods, much better than Apexi and about a third of the price.
If you find a store that stocks them, get them to fit it :laugh:
Same airbox, different intake piping (obv).
but remember the pod sits where the airbox would (seeing as its removed) so i dunno why a V35/PM35 one wont fit if they run the same airbox.
anyway, nothing is better than an apexi pod :laugh:
For the same reason that lovely Mishimoto radiator did not fit in my M35, bit fits straight into a G35/V35...
"anyway, nothing is better than an apexi pod :laugh:"
As usual, I enjoy your sarcasm, Iain!
thanks for that. ill see how i go about sourcing out a 3A Racing one. has anyone here have one on and would you need an adapter as well?
cheers!
Don't have one on (if I ever get around to my custom airbox I will though - so many things to do...), but here are the dimensions;
Width: 160mm
Height: 130mm
Neck: 77mm
The neck goes onto the pipe, so I guess if the measurement fits, it should* fit straight on your AFM if you take the adaptor plate off.
Alternatively, you could have an adaptor plate made up to fit?
OR you could just put a good quality panel filter in.
I've got a Blitz SUS Power Kit but havent put it in yet. It's still new in the box and I might be selling it as the car "might" be going.
From past experience, I've had no issues with the SUS Power filter. I used this on a 350Z and going on the track a few times (and going off into the dirt), the filter has worked pretty well and found no issues with any dirt going beyond the filter itself. What I did notice was dirty it was in a short period of time so had to clean it by blowing compressed air from the inside out.
They certainly are nice piece of kit.
Stainless Steel mesh, so no need to replace.
Can you post pics of the kit?
It is just the pod and the adaptor plate for attaching to the AFM, yes?
I paid about 70 bucks for a k&n panel filter, tho i have the power duct too.. probably the safest one to use i guess. f**k pods and other filters. hks ones cause loads of trouble for my precious front compressor wheel
  • 3 weeks later...
Which panel filter from K&N fits the M35? There are a shitload of them and I can't find one listed for the M35 or V35 anywhere (I read somewhere the V35 has the same airbox).
Don't want to get the wrong one.
if its to fit in the standard airbox, then yes the V35 airbox is the same. AFAIK the Z33 may also take the same filter. come to think of it, its a fairly standard size and i bet you about 50% of japanese made cars will take it. when i put my blitz in, the back of the box listed probably over 100 car makes and models that it suited.......
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
