Hi again my skyline friends from down under :P
So im looking into getting sway bars for my Skyline next. I have heard either Cusco or Whiteline is the way to go. What does everyone think? Pros and cons?
Heres what ive heard: Cusco is stiffer then whiteline but non-adjustable, and more expensive. Whiteline is not as stiff but adjustable but you have to buy there links too?? Im thinking whiteline due to cost and the adjustablity. I think pure balance will be better then just sticking in some really stiff sway bars from Cusco.
This will be going on a 1989 GTR
Front and rear upper adjustable control arms
Older Zeil coilovers
Cusco tension rods
Thanks Guys,
Your American friend Kirk :D
And i did try to Search this first but it wouldn't work for me.
Edited by Sportmax
https://www.sau.com.au/forums/topic/277198-sway-bar-opinions-r32-gtr/
  • Replies 51
Hi again my skyline friends from down under :sick:
Cusco tension rods
Thanks Guys,
Your American friend Kirk :)
In your location, 22mm front and 24mm rear Whiteline adjustable swaybars are most likely the go. But there is some cross over with anti roll and spring rates, so to be precise what spring rates are you running?
Cheers
Gary
Cheers
Gary
Im honestly not sure what my spring rates are. I know they are older KEI springs. They were on the car when i bought it. I could always measure them and figure it out if i get a chance to.
how much have you been quoted for the whiteline and cusco bars? in my experience the cusco bars were very good. i've tried both. they also come with new backets and bushes and they are literally half the weight of the whiteline ones. off the top of my head the cusco bars are about $320 or so. I agree that not having the adjustment is a bit of a downer, but to be honest once I was happy with the balance I never had a need to re-adjust my whiteline ones...
I found some Whiteline bars one Ebay for $350 plus shipping front and rear. My guy here in the states quoted me Cusco for $575 plus shipping for both.
He said i need Whiteline links to make the bars work, and that would make it about the same cost as the Cusco. The Cuscos are alot stiffer but with out corner balancing my car and getting different spring rates i won't be able to adjust them. Thats why im thinking the whitelines!?!?
Adjustability is all good up to a point. The point being you cannot adjust a Whiteline bar to be as stiff as a Cusco one. So you need to have a good think about what rates you run rather than just pick a bar because it is cheap etc.
Actually does anyone have the diameters (internal & external) for the Nismo bars???
imho since whiteline started shipping stuff out of china, their product quality's gone down the drain. I'd go cusco if i were you.
China? Korea more like it and most of the Skyline part numbers are still made locally as there isn't enough volume to justify the lead times from Korea.
Cheers
Gary
Thanks for the good opinions guys. Guess i have some thinking to do.
I know if i go with cusco bars i will need to get the car corner weighted to balance it out properly(which i want to do anyways, I just can't afford that right now) and i would like new coilovers before i do that.
Cusco being a lighter bar does sound good too.
I think i do have pretty good spring rates thats why i don't know if i need to go as stiff as cuscos. I don't have a ton of body roll and didn't even think i needed bigger sway bars untill recently.
You shouldn't be using excessive spring rates to control the roll, that's the job of the anti roll bars. Excessive spring rates simply limit the traction under braking and acceleration. Whereas the anti roll is only there when you need it, under cornering. Adjustable swaybars would always be my recommendation as quite simply they are the best way to tune handling balance. That's why race cars have driver adjustable swaybars. Adjusting an externally adjustable swaybar is far easier than changing spring rates to tune the handling balance
Cheers
Gary
Cheers
Gary
You basicly put my thoughts into words. Thats why i want adjustable. To much understeer, tighten the rear sway bar or loosen the front.
So you would still recommend Whiteline? I am having my guy price them out as we speak.
Do you know if you can use the factory links or have to buy Whiteline links to make them work??
Whiteline swaybars come with everything necessary to fit them to the car included in the fitting kit. In the case of an R32GTR that means D bushes only for the front as the standard ball jointed links work OK with the adjustment holes. The rear swaybar fitting kit has links as well as D bushes as the standard "I" links don't allow adjustment Unlike Subarus which have weak standard links, R32/33/34 front swaybar links are pretty tough, so no need for a heavy duty link kit.
On the race cars we use adjustable length spherical bearing links to faciliate corner weighting, but never reccommend using sphericals on a road car.
You will be OK with the off the shelf 22/24 swaybar diameters, there is plenty enough adjustment to tune the handling.
Cheers
Gary
Cheers
Gary
Thanks a ton man. This is why i am on this forum. You guys are all nice and definitly know your stuff when it comes to skylines. I asked the same question on our USA site and havn't gotten a single reply lol.
Think i made up my mind and will go with whitelines
Only problem i had with my whiteline adjustables was that the ends of the front bar touched the driveshafts, so they needed a bit of grinding. Other than that, all good.
When GTR's have a fair amount of caster that can be a problem, pulls the wheel forward and obviously the drive shafts go wth them.
Cheers
Gary
And occassionally dont come with the fittings they should. Or the wrong size fittings. Or with damaged threads, or end up denting your sumps. I hope they have got control of their quality again as during 2007-2008 it went to shit. Dont know what it is liek now :)
I bought a new set in January for the 32gtst and no problems such as these... guess you get some bad batches along the way.
Cheers
Gary
Im running 4 degrees of caster so hope that isn't to much. If i need to grind a little off i can do that no prob :yes:
I was looking at these. Looks like a good deal as long as they ship to the USA
http://cgi.ebay.com/R32-GTR-Whiteline-FRON...%3A1%7C294%3A50
Edited by Sportmax
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
