I have been following your build Ben from day one as we are also building a R32 and I have been impressed by your engineering.
I am a bit concerned that your data logger identified that the oil starvation happened under a braking situation.
We were of the opinion that the problem was more prevalent under cornering G forces and we designed and built our oil pan (RB25 in a R32) with hinges to control the sideways movement of the oil. We also included the return drain from the back of the head to the side of the sump.
Here are a few pictures:
What options are there to control the forward movement of the oil away from the pickup?
Usualy with any of the gated sumps i know of there is always 4 gates and they are layed in a dimond patern rather than square to the sump.
also i cant quite see but the oil fitting for the return from the head has to be on the passenger side of the engine. we have seen recently 2 race engines with fittings on the drivers sides presureising the head and not allowing the oil to return.
There would be twice as much force under braking than cornering in this car. if it was a circuit car with stiffer suspension and bigger grippier wheels than the corner Gs mite be grater but definatly not for tarmac.
Ben and i both know that this is not a common problem but we have also studdied the data that we have at hand and experiances we have had and have worked out that all the race rb20 we work with suffer from "extreemly low" oil pressure under heavy braking. its somthing that can easily be fixed with a combination of things that in total will be less than 1k.
Remember that theres only one reason engines spin bearings. you can chose to risk it and see how long the wrecker motor will go, or add preventitive measures to stop it happening half way through targa or at the end of a championship searies.
in the first page of SKs oil in rb's thread he says if your doing any kind of motorsport you should have a winged and baffeled sump.
As damo said, a dimond around the pickup is the go. This is a subie sump , but you get the idea.
I think 1/2 the issue with the std sump, is the front is at 45deg. so under braking it acts like a ramp, and not a wall.
Your never going to know without sticking a camera in there. But one of the circuit r32's down here has a greddy oil pressure gauge, and the warning light alwyas comes on under brakes. The other R32 down here that is quicker doesn't have a gauge, and that ran a bearing at the v8 supercar round last year, it was suspected it was under brakes. But we really don't know
haha, thanks Benji :)
So, you planning on doing Classic Adelaide? I'd like to opportunity to kick your arse, using my awesome Apexi N1 suspension. :P haha
I'd do all the rallies if I had the cash, so it's looking pretty doubtfull at this stage. I compared your 09 times to our times, so you already have kicked my arse.
Meh, 2009 is an age ago. Let's put it down to road degradation! :P
Come on, Adelaide will be good value. Stop cornering the market in Tenga Eggs and you'll afford it easy!
I spoke to Benson last week, he reckons she's good GTS-t country, not too many hairpins. And with Closey running Perry's thing, it'll be a good buzz :)
Here is my last corner weight. With approx 1/3 fuel and wearing R34 GTR wheels with Advan 265's.. AND 20kg of ballast in the driver's seat to allow for the difference between Timmy and I.
20kg in the drivers side! I thought it would be 20kg on the passenger's side :P
Whats the weight difference in the rear sides come down to you think?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
