Hello there,
I have this 1997 GTST-S2 genuine Skyline and I just had it for a few months.
The car is in perfect shape but when I release the clutch pedal in neutral I hear this faint grumbling and grinding noise.
(a co driver wouldn't notice the noise at all)
I had the same noise on my older BMW, but it was much more pronounced.
(and it happened to be the clutch bearing)
The Skyline's clutch operates perfectly fine so I am wondering if that noise is probably normal?
Thanks for the input ...
Cheers from London,
Andrew
Hi there and thanks for the input.
Should I replace the bearing or just ignore the noise?
If the clutch was not working properly I would replace the whole thing right away.
But it's just fine ..
Maybe I rather wait till the clutch needs replacement or the noise gets too loud to ignore.
Any thoughts on this?
Cheers from London,
Andrew
I think this is actually a gearbox bearing as the thrust bearing usually makes noise when the clutch pedal is pressed in, not when it is released.
Hi ..
I definitely think it's the bearing from the clutch (clutch release bearing).
It's a common diagnosis and I know the sound of it quite well :)
Cheers ...
It's the input shaft bearing. The throwout bearing makes a noise when you put the clutch pedal in.
When you drive down the road is the whine constant and does it make a sound sound similar to a straight cut gearset?
Hi!
There is no whining noise .. it's more of a grumble :)
And when I'm driving down the road you can't hear the noise since it's so faint.
Cheers ...
Edited by Torques
its the gear boxes front bearing thats shrown a .000somethink of a milimeter out of true ie: square of the shaft. got my car 1st owner in aus no noise at all then prob a week or 2 later and one trip to the drags meaning hard launches and warming tires cough cough....
it started makinging a grumbling and werrining (rotational friction) so week later i repaced the throwout flywheel and clutch with after market (extreme molly f.w.,xtreme button clutch comes with throwout.) noise still there that gere box is still going strong and noise hasnt got worse. its not worth the xpens to rebuild it.
Hi ..
It's a common diagnosis and I know the sound of it quite well :laugh:
Cheers ...
I bet I know the sound better :laugh:
I still disagree...if the sound occurs when you are releasing the clutch pedal then you can rule out the thrust bearing as this bearing only spins under pressure when pressed against the clutch pressure plate. The fact the noise only occurs in neutral suggests to me a bearing up the front of the gearbox, i.e. input shaft. Replacing this bearing will fix your sound but you may still be left with a rollover noise as per the tolerances being taken up.
Edited by Birds
I bet I know the sound better :pirate:
Hi Birds,
Thanks for insisting and I will check definitely consider your input.
I'm not sure though that the noise occurs only in neutral and will have to check.
Is there a workshop manual around that covers the gearbox?
Cheers,
Andrew
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
