i had iridiums in my 33 when i got it, they were in there for 20,000kms and were stuffed. put in coppers and they were still fine after 10,000kms. so the reason why iridiums aren't any good is because they are a waste of money.
  • Replies 129
Iridiums are also not ment to be gapped as it damages the end of them. Since most are 1.1 they tend to missfire on high boost applications, hence why most of us run a pre .8 gap on coppers.
y is every1 so against T bolt clamps, they hold on hydraulic hoses on mining equipment fine with 1000+psi im sure they can hold 20psi
n id also like the hear why iridium plugs are no good, i was thinking of getting a set coz arn't coppers only good for like 10,000 clicks?
If you think the iridi's will last 100,000 like they claim - forget that idea.
In a stock application, ye probably, but in a modified one with extra boost - unlikely.
Why pay $120 for a set of plugs that can foul as easy as coppers anything can foul them really, eg: your fuel reg dies, there goes $120 in plugs.
And say thats only 15,000km's into the set, all of a sudden the coppers are worth their price because you change them frequently.
Plugs are like an oil filter, in a modified application change them often, this is a family magna your talking about.
whole heartedly agree...
my last set of coppers were pulled out after 20,000 just for good measure and were still running fine at the time. and that's with 300 very abused rwkw...
the set before that lasted just as long
and the set before that were iridi's and were thrown out after 5,000 odd
Then they most likely are platinums, not iridiums. Not many places keep BKR7EIX in a .8 in stock (atleast that's what i find), most keep the BKR7EIX-11.
EDIT: I just checked back a page and you said PFR7B, yep Platinums.
Edited by PM-R33
yes they come in both 0.8mm gap as well as 1.1, but if you get the 1.1 (which is the factory specified gap for rb motors) they recommend not changing the gap down to 0.8 with the iridiums as it can damage them.
awsome they were the answers i was looking for, so looks like im gna get a set of coppers. while we're on the topic of plugs, what part number do i need or what heatrange should i get and what should i gap it too. they're going on a usual sub 200rwkw rb25 running 10-12psi, im also gonna be changing to splitfires the same time as the spark plugs go in.
cheers
power is a simple calculation of
air + fuel + spark + compression = power
whats the tune like?
whats does the AFR look like on max load?
how is the ignition timing tuned?
whats base idle timing ? check it with a timing light?
got it booked in for monday to be seen by another tuner and have this issue diagnosed.
i dont think the turbo is out of puff as ive seen several other rb25's make atleast 270...and im finding it hard to make just up to 245-250rwkw at anything over 14psi.
plus im getting a massive pressure drop without any detonation...so how can it be producing hot air???
Edited by allthewaytotheskyline
found my problem (fingers crossed)
leaking exhaust gas out of a 10mm bolt hole kinda like a little wastegate that constantly open
which would explain why it would hit 18psi then come back down to 15psi
I think its going to go back into the car with a .82 external gate setup now its all out
also i found a crack at the wastegate hole .I dont think that would have been helping my situation either
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
