  • Replies 55
Posted Images
syfon just do what i said earlier to see if you actually want it to dose. dc your vacuum hose block it with a bolt then block the little thingy the vacuum pipe goes on and drive around like that. coz i hear flutter and think its cool. then after having my own car flutter for a min it annoys to hell out of me
Not a fan of angry pigeon, but do it right not the whole piece of coke can inbetween bov.
on a sidenote: Anyone got a stock GTR Bov or Stock GTST Bov.... must get rid of hks ssqv
did your hks ssq sound similar to that? i remeber u took me for a drive wen i bought that smic off ya, i remeber it sounded alrite i cant remeber what noise it made lol
i hate the high pitched vl dose vvvvvvvvddaaadddaaaadddddooo doesnt sound tuff just sounds wank
i've got a stock R33 GTS-t BOV, wana straight swap for the HKS SSQV?
yeah mine sounds similar, will sound better when high mount and bigger turbo goes on :D
  • 1 year later...
so i have a 1993 R33 Gts-t ,
should i even try to make my car dose? im interested in trying it once, but i cant tell exactly what to do, coz theres so many different answers.
would i have to block the bov with the coke can, ASWELL as plug the vacuum line with a coke bottle lid?? some say you only need to do the coke can, some say you only need to block the vacuum?
or would it be a bad idea to try it for a day considering im still running the ceramic stock turbo?? plus i dont know how its been treated in the past...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
