I plan on buying a new ecu in the coming weeks and I need a little help deciding which way to go. The car is an R32 with RB20DET and i've just installed a larger turbo, new manifold, external gate, cams and ajustable gears, ebc and a few other things.
I'd been planning for a while to go with the Nistune, until i went and spoke to the only local guy that does dyno tuning. (I'm out in the sticks). He's never had any experience with the Nistune, but he's a Vipec dealer and has done a few of them in skylines now.
So what I'd like to know, is whether either of the ecu's have any specific advantages? I do like the advantage of my car being tuned locally by a guy with a bit of experience on similar setups, but I also like the price of the Nistune.
https://www.sau.com.au/forums/topic/278238-nistune-vs-vipec/
  • Replies 67
Yes the Vipec is a very decent ecu. You should go with it. However your tuner should also be able to tune a Nistune.
The vipec cannot be compared to the Nistune because they are totally difference ecu's. You can compare a power fc and a nistune like you can compare a Vipec & Motec.
They are totally different. one does the job and works okay, the other does the job and can make you breakfast.
If you go down the vipec route, you can pull out your ebc and use the vipec to control boost for just a added $130 part so you can get the vipec for a bit cheaper and have decent boost control as well.
for the price you can't beat nistune. it gives you all the features you need as far as being able to change injector size, afm and do full adjustment of ignition and fuel maps. and most of all, full installed and tuned it will probably cost a lot less than just buying the vipec ecu, which would then leave money in your pocket for other mods
There's one tuner in town and he does vipec. He's done a few skylines and some silvias and supras with vipecs now. His main clientel is v8's but he seems to be a decent tuner.
Other than that its a 5 hour drive to Sydney or 4 hours to Canberra.
Nope. I don't really mind towing the car to be tuned if i have to, but thats basically gonna add a few hundred bucks to the cost, and i still wouldn't have local support if something were to go wrong.
Vipec is starting to look like an attractive option! :laugh:
by the sounds of it vipec is the most viable option.. after you take in costs of towing etc if something goes wrong and so on.. might be a better to have a higher initial outlay of $$$ to save furhter $$ in the future "incase" something goes wrong
have you asked your tuner about power fc ?whats your plans with the car & whats the mod list, if its just basic upgrades, there is no need to go vipec.
Listed most of the mods in the first post. Its nothing crazy, but its further than the basic upgrades most people do. The turbo is a HKS T300s but i will most likely change that fairly soon anyway to something a bit newer and slightly more responsive. :pirate:
Thats pretty much the same train of thought i'm having.
in your situation with the distance i would go with what the tuner advises.
but i am looking at getting a Nistune soon, basically because my car is just a streeter, my tuner does both. and obviously i am gonna go the cheaper option because all i need is to maybe have the timing and fuel maps changed, and possibly allow for larger injectors and the Nistune will do that.
but i have heard great things about the Vipec, but i think $14k is enough to spend on a car in 8 months!
time to start holding onto my money
brez
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
